Thread Number: 92419
/ Tag: Classified Ad Finds
Frigidaire Dishwasher |
Post# 1170345   1/25/2023 at 18:33 (464 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1170357 , Reply# 1   1/25/2023 at 21:04 (464 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1170364 , Reply# 2   1/25/2023 at 22:47 (464 days old) by appnut (TX)   |   | |
Post# 1170365 , Reply# 3   1/25/2023 at 22:49 (464 days old) by Tomturbomatic (Beltsville, MD)   |   | |
The door handle is original. The start button at the upper right is genuine, too, and started the machine without the user having to reach down to the timer dial. |
Post# 1170370 , Reply# 4   1/25/2023 at 23:27 (464 days old) by appnut (TX)   |   | |
I had to be between 4 and 5. There was a family that my sisters went to elementary school with. I remember one time stopping by their house in the morning after my mom had dropped my sisters off at school. And it's the only time I remember being at their house. I remember they had what I figured out later was a dishwasher and it had the birght orange thing on it that was exactly my height for my eyes. And I knew it was different than my aunt's KD11 or KD12 because the KA just had a smaller little orange light that glowed when it was on than the big orange glow light. It was not util I was in Robert's kitchen at the 2001 Minneapolis wash-in and recognized that same orange glow light on the dishasher panel. And I knew I was finally able toidentify the brand of tat dishwasher--a Frigidaire like this one. In talking with my dad about me finally being able to identify the dishwasher this family had he told me the husband worked for P&G and they had been transferred to Houston for his job. In the conversation with my dad when I told him about that memory being this family's kitchen, my dad told me they also had 2 washers and dryers. I don't remember ever seeing their washer & dryer, I think my mom knew better than to let me go see them.
Post# 1172295 , Reply# 6   2/15/2023 at 10:46 (443 days old) by turquoisedude (.)   |   | |
Sadly parts for these dishwashers are not easy to come by... There was a pump shaft seal that was prone to failure which caused the machines to leak. It wasn't all that difficult to replace, but the parts got used up a very long time ago.
I've never tried it myself, but it may be possible to adapt an entirely different pump into one of these dishwashers.
I've come across a few, still have one (actually just like the one you'll be going to look at) and I had "fun" restoring it... |
Post# 1172602 , Reply# 8   2/18/2023 at 17:29 (440 days old) by Delco1946 (Oregon)   |   | |
Some pics from the underside - guessing there was a water leak. Any suggestions as how to tackle this? |
Post# 1172652 , Reply# 10   2/19/2023 at 07:07 (440 days old) by William637 (Damp pants? Not a chance. )   |   | |
Those are fun dishwashers, but the gaskets are problematic. I have made gaskets for two machines. One worked perfectly, the other I never could get to seal. I put that one aside several years ago and haven't returned to it.
The original gaskets were cork. So I went to an automotive supply store and bought a small roll of cork gasket material. I then very carefully removed the gasket from the dishwasher and traced it onto the roll material to cut it out. The automotive store I went to also sold gasket material that was synthetic. The cork seemed to work better. Finally, if I remember correctly, the drain valve solenoid also has a gasket. I had less success with that one. If you aren't ever going to the assemblies apart again you could consider using a silicone type sealant, just be aware of the more more permanent nature of your fix. |
Post# 1172660 , Reply# 11   2/19/2023 at 08:19 (440 days old) by Unimatic1140 (Minneapolis)   |   | |
I remake cork gaskets all the time on my vintage washers and dishwashers. Here is what I normally use (see link below), I found this material is much easier to cut without ripping than standard cork roll and has never leaked. I wouldn't recommend using silicone on the pump assembly as it will make any future repairs more difficult, not impossible but a lot more work than would be otherwise necessary. Silicone should be fine for the drain valve however.
amzn.to/3lMmBnt... Since you asked I will move this thread to the Imperial Forum. |
