Thread Number: 92440
LG WM3600 water level can still easily be raised |
Post# 1170598 , Reply# 1   1/28/2023 at 21:24 (454 days old) by ea56 (Cotati, Calif.)   |   | |
That looks like a vast improvement in the water level. I used to have a LG FL about 7 years ago and the water level in photo #2 is what I got, which is not enough water to properly wash clothes in my opinion. I would probably been much happier with it had I known that I could have raised the water level.
Also, that LG wasn’t good at finding a sweet spot and spinning properly with heavy towels and other heavy loads. Often times it just would NOT spin. I hope they’ve fixed that flaw. Eddie |
Post# 1170601 , Reply# 2   1/28/2023 at 22:09 (454 days old) by appnut (TX)   |   | |
Eddie, in my experience, they have fixed the heavy towel load balancing. My 10 sets of towels filled the drum totally when all pieces were in. By the time it finished doing the main wash and 4 rinses, it ony added a total of 6 minutes to the cycle by the time it had finished. Far better than the Duet did with this type of load.
Post# 1170603 , Reply# 3   1/28/2023 at 22:49 (454 days old) by kenc (SF Bay Area)   |   | |
I just put a "heavy duty" load in, and a pool of water is visible in the bottom of the drum, it was not before the mod. The water level is still well below the glass. I think I like one turn of the screw. |
Post# 1170610 , Reply# 5   1/29/2023 at 02:39 (454 days old) by mark_wpduet (Lexington KY)   |   | |
PERFECT
I totally agree with you...that looks like the perfect level.. Not too much but not too little. I think people who adjust these - some of them go overboard...you really just need a little more.. Why they can't give you that in the first place is beyond me...even where you adjusted it, that's not like a swimming pool of water, but it's enough...I'm sure even rinses are higher.. I'm paranoid to try this though because of a horrible experience I had with my Duet YEARS ago... Maybe around 2007, there was this thing going around how to get more water in your Duet...I could never get it right.. Here's what would happen: I would turn the screw like a quarter, check the fill level, and it kept looking like "default" every time I would turn the screw a little... essentially nothing changed...until all of the sudden, after several small turns, it would from defalt to almost 1/2 up the glass... I could never find a happy medium... so I moved it back and haven't screwed with it sense... But again, this might be different than the whirlpool from 2005.. |
