Thread Number: 92613
I thought the VMW washers sounded terrible...then I found this |
Post# 1172034   2/12/2023 at 12:00 (440 days old) by ryner1988 (Indianapolis)   |   | |
Do all high efficiency top load washers just sound absolutely atrocious when running? Who the heck could stand listening to the sound of this Samsung top load washer on laundry day? I suppose it wouldn't be too bad if you could close your laundry door, but if your laundry is in your kitchen, or as in my case a closet right in the main part of the house, that agitation sound would grind your nerves so fast!
That settles that. If the time should come that I need a new washer, I'm getting a front loader or I'll do whatever I have to do to get a Speed Queen if I go top load, as they seem to be the only ones left that don't use a reversing motor with that horrible grinding pulse. Are there any high efficiency top load washers that don't sound like crap? Curious minds want to know. |
Post# 1172092 , Reply# 2   2/13/2023 at 02:30 (439 days old) by maytaga806 (Howell, Michigan)   |   | |
I KNOW RIGHT!?!? It’s gut wrenching to hear. Those nasty GE ones too are even worse. The struggle it sounds like they have with every load because with most of those wash plate HE machines aren’t using enough water and it’s adding so much stress onto these motors by agitating a full load of fabrics with very little water. We had a cabrio for so long which was not my choice, absolutely awful. It was a total game changer for the laundry in a bad way, couldn’t let the dang thing fill with the lid open, had the stupid lock on it, didn’t have an agitator had a wash plate I absolutely despised it from the first day our grandparents got tricked into buying them after years of having direct drive washers and simple matching dryers. When I moved out I got my own direct drive and it was like my childhood all over again simple easy quick laundry by a machine that doesn’t sound like it’s struggling or having to sense and balance a load, if I had a dollar for everytime that cabrio went out of balance and had to re balance itself I wouldn’t of ever needed a job. Horrendous machine. It spewed oil after 11 years and the matching dryer is still going but it’s had repair after repair after repair.
Post# 1172098 , Reply# 4   2/13/2023 at 06:48 (439 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Samsung impeller top load washer,
I can’t believe you can use all that water to wash just five pairs of jeans and you can still see the dirty spots where they’re all roped up and tangled. The day of the top loading washer is over. I don’t know why anybody would buy one of these machines. What you spend in water is ridiculous and detergent to even try to get things clean. John. |
Post# 1172111 , Reply# 5   2/13/2023 at 11:32 (439 days old) by ryner1988 (Indianapolis)   |   | |
Reply #3, that washer is not mine, thank God. I just saw it on Youtube while poking around and wanted to share the horror LOL
Reply #4 yes John I agree with you completely. If I needed a new washer I would definitely get a front loader as I don't believe a top loader can be made high efficiency and do very well. My current traditional non-HE TL machine works just fine though and I don't see any reason to junk a perfectly working machine, I will use it until I can't any longer. If I had a large family I might be more concerned about the amount of water/detergent it uses however it's just my wife and I and I only do about three loads a week on average. But yes, HE TL's suck majorly. I would never buy one. A TL operates like a TL and an FL operates like an FL. You can't really make a hybrid and have it work. |
Post# 1172112 , Reply# 6   2/13/2023 at 12:26 (439 days old) by qsd-dan (West)   |   | |
Post# 1172225 , Reply# 7   2/14/2023 at 17:18 (438 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1172235 , Reply# 8   2/14/2023 at 19:24 (438 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
I'd brush those jeans off a bit first, then my trusty Maytag A606 would make quick work of having them clean and well extracted in a mere 28 minutes. |
Post# 1172239 , Reply# 9   2/14/2023 at 19:43 (438 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1172246 , Reply# 10   2/14/2023 at 21:11 (438 days old) by qsd-dan (West)   |   | |
Post# 1172301 , Reply# 11   2/15/2023 at 13:39 (437 days old) by Frigilux (The Minnesota Prairie)   |   | |
Mr. Rivas washed a similar load in a “classic wash” SQ with a 2nd rinse. Results weren’t pristine, but he washed in cold water.
A wash plate top-loader would be my absolute last choice for a washer, but would take one over, say, having to go to the laundromat. I thought LGs had a long end-of-cycle signal, but this one is at least three times longer. Yeesh! A few beeps will suffice, thank you. |
