Thread Number: 92634
/ Tag: Modern Dryers
G E DRYER |
Post# 1172206   2/14/2023 at 13:09 (584 days old) by Frigidaireguy (Wiston-Salem, NC)   |   | |
I work with a friend that has a G E dryer that is approx. 17 yrs old. It has developed a "squeaking" sound. I think it maybe the bearings going out. Would appreciate any thoughts. Thanks !!!! Bob |
Post# 1172207 , Reply# 1   2/14/2023 at 13:13 (584 days old) by ea56 (Cotati, Calif.)   |   | |
Post# 1172210 , Reply# 2   2/14/2023 at 13:50 (584 days old) by Frigidaireguy (Wiston-Salem, NC)   |   | |
I forgot to mention that the Squeak will go away after the machine runs for approx. 30 minutes. Bob |
Post# 1172247 , Reply# 3   2/14/2023 at 21:39 (583 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1172258 , Reply# 4   2/14/2023 at 22:30 (583 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1172289 , Reply# 5   2/15/2023 at 08:29 (583 days old) by Frigidaireguy (Wiston-Salem, NC)   |   | |
What would cause it to stop the noise after approx. 30 minutes ??? Just wondering Bob |
Post# 1172290 , Reply# 6   2/15/2023 at 09:47 (583 days old) by DADoES (TX, U.S. of A.)   |   | |
Unhealthy sounds are difficult to diagnose from afar without hearing the noise and zeroing-in to the location on the machine. The model number also isn't cited. Typical GE dryer design of that time likely involves moving parts of the motor/pulley, idler/tension pulley, belt, rear drum bearing, and the drum, the front rim of which rides on four "bearing" slides affixed to the support rim of the front panel. One never knows what's causing a noise without hands-on examination. One of RJ's rental tenants reported a screeching noise last year on the provided Whirlpool top-filter dryer. I had repaired it several months prior for a bad drum support roller. I found on disassembly that a plastic clip of some ilk had attached to the front panel rim that supports the drum and the rim of the drum was riding on the clip instead of the felt pad. Screeeeeee!! |
Post# 1172393 , Reply# 8   2/16/2023 at 05:33 (582 days old) by askolover (South of Nash Vegas, TN)   |   | |
