Thread Number: 92642
/ Tag: Modern Dishwashers
Miele Dishwasher Issues |
Post# 1172341 , Reply# 5   2/15/2023 at 16:27 (437 days old) by Jerrod_Six (Eastern Pennsylvania, USA)   |   | |
Henene4: Do you have a picture or schematic showing where the pressure switch is located? Tomwasher18: How do you get into the service mode on your SCVI machine since it has the OK button? Thanks to both of you. |
Post# 1172477 , Reply# 13   2/17/2023 at 17:26 (435 days old) by ozzie908 (Lincoln UK)   |   | |
Is I believe connected to the heater not the actual water level in the machine its to ensure there is sufficient water to operate the heater.
My first place to look would be the water matrix usually on the left hand side as you face the machine check for any debris in it and maybe with a little luck you may see the problem as unless they have drastically changed the workings this matrix can and often does clog up with grot. Good luck and keep us posted of your findings... |
Post# 1172751 , Reply# 23   2/20/2023 at 16:01 (432 days old) by Jerrod_Six (Eastern Pennsylvania, USA)   |   | |
Wow Yes, that is a lot of water since it normally only covers the filter area. It's got to be something that is making the machine think it needs to add more water so I Hope the replacement part will fix this problem. |
Post# 1173482 , Reply# 24   3/2/2023 at 01:20 (423 days old) by richnz (New Zealand)   |   | |
Do you hear water being sprayed with force or just a weak spray? |
