Thread Number: 92676
Speed Queen oil weight |
Post# 1172629 , Reply# 1   2/18/2023 at 21:16 (434 days old) by Maytag85 (Sean A806)   |   | |
Post# 1172631 , Reply# 2   2/18/2023 at 21:59 (434 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I think a lot of manufacturers specified 60 weight. I could be wrong but I think GE did too in their washers with transmissions as did Speed Queen. |
Post# 1172687 , Reply# 3   2/19/2023 at 16:45 (433 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I'm trying to find the exact weight of the oil that Speed Queen uses. Wouldn't 60 weight oil be too light on the gears? I wouldn't want to put 140 weight oil as it will be dragging the gears. |
Post# 1172709 , Reply# 5   2/19/2023 at 20:05 (433 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I've always wondered what the composition of each oil is. I know that whirlpool uses 90 weight gear oil and GE used 40 weight grease in their filter-flos. It seems that Speed Queen transmissions don't get as hot and may use a lighter oil I assume about 60w oil. |
Post# 1173892 , Reply# 6   3/6/2023 at 06:18 (418 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Keep in mind that thinner and lighter oils actually lubricate better and protect gears better, look at the example of an automatic transmission, which can handle hundreds of horsepower under stressful conditions.
Heavier oil’s may make it run a little quieter but they do use more energy, which is very important in an automobile Oil weight probably doesn’t really matter in the washing machine you could use anything from 60 to 100 weight probably with no different results. John |
