Thread Number: 92734
maytag el2 pulley |
Post# 1173079   2/25/2023 at 15:19 (433 days old) by christfr (st louis mo)   |   | |
hey all what im trying to do is add a drain pump to my el2 . i can get the parts i need except for the diff style pulley thats on the trans that will engage the pump wheel. does anyone have a used one for sale or a any idea where to find one.
Post# 1173134 , Reply# 1   2/26/2023 at 07:16 (433 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Try Bunker Hill Appliance in Ohio - 1-330-893-3700. Great people and what they don't know about Maytag wringer washers is no body's business.
Next up is another Amish business (they do love their Maytag wringer washers), is Cottage Craft Works: cottagecraftworks.com/maytag-wri... |
Post# 1173169 , Reply# 2   2/26/2023 at 14:45 (432 days old) by christfr (st louis mo)   |   | |
Post# 1173362 , Reply# 3   2/28/2023 at 05:41 (431 days old) by christfr (st louis mo)   |   | |
Post# 1173374 , Reply# 4   2/28/2023 at 10:32 (430 days old) by bradross (New Westminster, BC., Canada)   |   | |
Post# 1173375 , Reply# 5   2/28/2023 at 10:36 (430 days old) by bradross (New Westminster, BC., Canada)   |   | |
Post# 1173414 , Reply# 6   3/1/2023 at 05:15 (430 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Try this eBay seller, he seems to have lots of vintage Maytag wringer spares on offer.
https://www.ebay.com/str/1man5women... |
Post# 1173489 , Reply# 7   3/2/2023 at 06:06 (429 days old) by christfr (st louis mo)   |   | |
Post# 1173674 , Reply# 8   3/4/2023 at 09:58 (427 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1173692 , Reply# 9   3/4/2023 at 14:46 (426 days old) by christfr (st louis mo)   |   | |
Post# 1175310 , Reply# 10   3/20/2023 at 13:28 (410 days old) by christfr (st louis mo)   |   | |
Post# 1175509 , Reply# 11   3/21/2023 at 21:27 (409 days old) by Stan (Napa CA)   |   | |
Post# 1175544 , Reply# 12   3/22/2023 at 05:54 (409 days old) by christfr (st louis mo)   |   | |
well ran it did three loads of laundry no leaks and it actually worked. had no idea the pumps were so strong its like a fire hose . was able to get a pic but for what ever reason my phone wont take a vid. ill try and work on that .. sorry
Post# 1175547 , Reply# 13   3/22/2023 at 07:37 (409 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Pumps on Maytag wringer are rather powerful. IIRC Maytag stated pumps would empty tub of water in about two minutes.
Have mine set up a few feet from sink using an extension to drain hose and am here to tell you water still gushes forcefully when pump is engaged. When done with wash day don't forget to lower drain hose to ground so remaining water will clear out of sump and hose. |
Post# 1175577 , Reply# 14   3/22/2023 at 14:19 (408 days old) by christfr (st louis mo)   |   | |
Post# 1175634 , Reply# 15   3/22/2023 at 17:14 (408 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
I just take off black plastic ring off end of drain hook and slip on hose (standard drain from a dishwasher), then clamp down. When wash day is done reverse proceedure and replace black plastic ring.
You'll need to ensure hose slips on a good inch or two and is clamped tightly. Otherwise am here to tell you force of drain pump will push it off otherwise. |
Post# 1175720 , Reply# 16   3/23/2023 at 06:22 (408 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I remember my grandmothers E2LP model well, it drained into a shallow sink so we just had to feather the control for the drain pump so you didn’t engage fully otherwise it would splash all over the laundry room.
When you’re rinsing out the machine after you drain the wash water always dump at least a half gallon of clean water through so you don’t have any stinky wash water Staying in the drain pump if the machine is used regularly you should actually leave water in the pump. If you’re only going to use it once every six months it wouldn’t hurt to drain it completely. John. |
Post# 1175725 , Reply# 17   3/23/2023 at 07:56 (408 days old) by christfr (st louis mo)   |   | |
Post# 1175727 , Reply# 18   3/23/2023 at 07:58 (408 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 1175760 , Reply# 19   3/23/2023 at 14:50 (407 days old) by christfr (st louis mo)   |   | |
it was in pretty good shape when i got it. just did a paint job cause that had yellowed and a good clean and polish. i had seen it online at a junk store about half an hour away for 200 and the pics looked so good i thought id go see for myself. got there it was in the corner with a price tag for 100 so i bought it.
