Thread Number: 92746
1986 Kenmore 80 Series Spin Problem |
Post# 1173172   2/26/2023 at 14:57 (432 days old) by Ashaw86 (Spartanburg, South Carolina)   |   | |
Hey everyone. I have been having issues with my 1986 Kenmore 80 series washing machine. It fills, agitates, and neutral drains, but when it gets to the spin cycle it just hums. If i give it a spin by hand it try’s to spin but stops. Then other times will spin but not as fast as normal then slow and stop while it’s still humming and should be spinning. I just replaced the transmission and clutch. I thought it was the basket drive so I did that today. Still no spinning. I took the case off and saw the clutch spinning so I am not sure what the issue is. Can anyone help?
Post# 1173211 , Reply# 1   2/26/2023 at 19:03 (432 days old) by coldspot66 (Plymouth, Mass)   |   | |
Is something caught between the inner and outer tubs? |
Post# 1173212 , Reply# 2   2/26/2023 at 19:03 (432 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1173268 , Reply# 3   2/27/2023 at 04:14 (432 days old) by Ashaw86 (Spartanburg, South Carolina)   |   | |
Post# 1173269 , Reply# 4   2/27/2023 at 04:41 (432 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi, since you replace the Braska Drive, I assume you took the wash basket out and could eliminate anything stuck between the outer tub in the wash basket.
The basket drive should turn easily in the bearings. Be sure they’re fully lubricated. There’s a possibility that the basket drive block could be worn and the basket could be sitting down too low and dragging on the bottom of the plastic outer tub make sure the ears on the basket Drive shaft, engage in the basket, drive block. If you have the clutch in your hand, you should barely be able to turn the clutch band inside the clutch drum. If you can turn it easily by hand, the clutch is no good. Let us know what else you find. This should be an easy fix. John |
Post# 1173378 , Reply# 5   2/28/2023 at 11:07 (431 days old) by ryner1988 (Indianapolis)   |   | |
Post# 1173381 , Reply# 6   2/28/2023 at 12:56 (430 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1173426 , Reply# 7   3/1/2023 at 12:26 (429 days old) by ryner1988 (Indianapolis)   |   | |
Ok gotcha, so the spin gear either works or it doesn't there's no in between. That's what I'm guessing from your comment?
I've really only ever heard of this issue being the clutch. It was on my machine when it was worked on a couple months ago. It had a lethargic ramp-up to spin and it was getting to where it would not complete large loads at full speed. Changed the clutch and all was well. Also changed the transmission to fix the neutral drain issue, so that a new clutch wouldn't wear quite so fast. OP, did you ever sort out your spinning issue? |
Post# 1173886 , Reply# 8   3/6/2023 at 04:30 (425 days old) by Ashaw86 (Spartanburg, South Carolina)   |   | |
I haven’t gotten the spin problem fixed yet. I am going to replace the tub support with the bearing and seal kits installed. Hopefully this is the problem as the inner tub is really tight to spin by hand. It has went to not spinning at all no matter if I help it or not. The agitator will spin but the tub will not while it is in spin cycle. I will update again later this week after I install the tub support.
Post# 1173901 , Reply# 9   3/6/2023 at 09:13 (425 days old) by DADoES (TX, U.S. of A.)   |   | |
