Thread Number: 92783
What's this noise? |
Post# 1173529   3/2/2023 at 17:42 (428 days old) by BlockEight88 (Hobart, IN)   |   | |
I finally got my Kenmore Ultra Fabric Care washer/dryer set from 1994. I just replaced the pup today with a brand new one. I'm not sure what this noise is? I'm thinking it may possibly be the transmission? Any help would greatly be appreciated. I do plan on making this machine like new. The noise kind of sounds like the agitator dogs, but I don't think it's that, since I just replaced them.
Post# 1173530 , Reply# 1   3/2/2023 at 17:44 (428 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 1173531 , Reply# 2   3/2/2023 at 17:50 (428 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1173536 , Reply# 3   3/2/2023 at 18:13 (428 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1173565 , Reply# 4   3/3/2023 at 07:55 (427 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1173571 , Reply# 5   3/3/2023 at 11:10 (427 days old) by ryner1988 (Indianapolis)   |   | |
Post# 1173589 , Reply# 6   3/3/2023 at 14:56 (427 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1173592 , Reply# 7   3/3/2023 at 15:59 (427 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1173598 , Reply# 8   3/3/2023 at 18:42 (427 days old) by ryner1988 (Indianapolis)   |   | |
Could be bad bearings, although I've heard that is more of a screeching rather than the squeak this machine is making. I'd be inclined to think it's coming from the gearcase.
Are you going to just replace the entire gearcase, or rebuild that one? Definitely would recommend replacing the coupler and upgrading to a heavy-duty 6-pad clutch. |
Post# 1173599 , Reply# 9   3/3/2023 at 19:01 (427 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1173605 , Reply# 10   3/3/2023 at 20:22 (427 days old) by ryner1988 (Indianapolis)   |   | |
Post# 1173648 , Reply# 11   3/4/2023 at 07:17 (426 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1173658 , Reply# 12   3/4/2023 at 08:49 (426 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It’s not the drive coupling, and probably not the transmission, to me it sounds like something loose getting in the pump and rattling around a bit.
Would recommend not worrying about it just keep using it and see if the problem gets better or worse if it’s something in the pump, it’ll probably go away. John |
Post# 1173670 , Reply# 13   3/4/2023 at 09:32 (426 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1173682 , Reply# 14   3/4/2023 at 12:59 (426 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1173842 , Reply# 15   3/5/2023 at 17:40 (425 days old) by BlockEight88 (Hobart, IN)   |   | |
