Thread Number: 92800
MVWP575GW Issue |
Post# 1173734 , Reply# 1   3/4/2023 at 19:43 (419 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Sounds like Maytag is a big scam with their so-called "commercial-grade" parts. |
Post# 1173736 , Reply# 2   3/4/2023 at 19:49 (419 days old) by DADoES (TX, U.S. of A.)   |   | |
Could be the transmission pulley bolt loosened and the pulley dropped down and is rubbing on the belt guard, and also slipping on the drive shaft splines. Check and deal with it quickly to avoid escalated damage. The fix could be simple as tighting the nut, and put some blue (non-permanent) Loc-Tite on the threads. Worst case you'd need a new pulley kit (use the Loc-Tite on it) and belt guard. Or maybe the problem is something else. |
Post# 1173738 , Reply# 3   3/4/2023 at 20:09 (419 days old) by petek (Ontari ari ari O )   |   | |
