Thread Number: 92801
Kenmore wash tub not aligned |
Post# 1173683   3/4/2023 at 13:03 (426 days old) by BlockEight88 (Hobart, IN)   |   | |
I'm really stumped by this. I thought that replacing the suspension springs, suspension retainer clips, and counter balance spring, this issue would resolve. Why is the tub not properly aligned? The machine is perfectly level. While it operates normally, I'm still bothered by this. Any input would be greatly appreciated.
Post# 1173699 , Reply# 1   3/4/2023 at 15:22 (426 days old) by DADoES (TX, U.S. of A.)   |   | |
Is the counterbalance spring properly matched to the motor? Mounted at the proper position? Did the base rail mounting hole wear through and a new hole was drilled further to the left? The slight misalignment isn't a serious problem either way, functioning of the machine is not affected.
Post# 1173701 , Reply# 2   3/4/2023 at 15:37 (426 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1173703 , Reply# 3   3/4/2023 at 15:43 (426 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1173705 , Reply# 4   3/4/2023 at 15:51 (426 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1173707 , Reply# 5   3/4/2023 at 16:36 (426 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1173778 , Reply# 6   3/5/2023 at 08:11 (425 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1173826 , Reply# 8   3/5/2023 at 15:32 (425 days old) by BlockEight88 (Hobart, IN)   |   | |
