Thread Number: 92803
Need help with 1996 WCI front loader |
Post# 1173712 , Reply# 1   3/4/2023 at 17:05 (426 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1173713 , Reply# 2   3/4/2023 at 17:08 (426 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Does the humming sound rev way up if you put it in the final spin cycle?
If so, the belt could be off the pulleys. If you just get the same home anytime the main motor supposed to run, the brushes could be stuck on the motor or you could have a bad circuit board. We used to see that sometimes on this model. These were fun washers and fairly good performers, not real durable, but if you treated well, you can get a lot of use out of it. John |
