Thread Number: 92996
What would cause water to seep from a drain pumps weeping hole? [pic included] |
Post# 1175921 , Reply# 1   3/25/2023 at 02:23 (406 days old) by qsd-dan (West)   |   | |
Post# 1176538 , Reply# 3   3/30/2023 at 07:42 (401 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
There are all kinds of things you might be able to do to a 30 year old washing machine that you want to keep using, it depends how much effort you want to put into it. You may also destroy it or certain parts of it if you try to take it apart,
You certainly could replace the belt while you’re doing the pump you might consider replacing the rubber boot around the transmission, however, you have to be able to pull the agitator and get the inner tub out. Sometimes that’s a problem in a machine this old and you may end up uncovering, rust issues, etc. , John |
Post# 1176635 , Reply# 4   3/31/2023 at 06:18 (400 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
No washer manufacture ever made a machine that could be damaged by changing settings while you were using it.
There was only one Maytag AMP machine that had two speeds the model 140 where you could change it when it was operating and it wouldn’t hurt a thing you could do it all day long if it broke when you happen to do it, it was just a coincidence, The solenoid on the two speed clutch assembly of a GE washer was only used to hold it in low speed, the two speed clutch always starts out on low speed, you can shift a GE from low to high while it’s operating and it will work just fine. You could also attempt to switch a GE from high to low while it’s operating but the safety system will just let it stay in high speed. It won’t switch to low until the machine comes to a stop, but it won’t hurt a thing. if the solenoid linkage is damaged, as Brad mentioned could happen in reply number 11, it was out of adjustment and broken to begin with. Reply number nine the solenoid is used to hold it in low speed. It has nothing to do with high speed. One of the worst things about Filter Flow washers. What is the silly two speed clutch GE used, it’s ironic. One of the worlds largest manufacturers of motors, used this silly system in their washers, while manufacturing great two speed motors for almost every other washer manufacturer. John |
Post# 1176643 , Reply# 5   3/31/2023 at 09:49 (399 days old) by DADoES (TX, U.S. of A.)   |   | |
John, for reference, what happens on a typical vintage topload washer with a motor that reverses direction for agitate vs. spin/drain if the timer is turned to a directional change without first stopping the motor? Does it continue running in the same direction without any ill effect since the centrifugal start switch doesn't re-engage for the reversal? |
Post# 1176647 , Reply# 6   3/31/2023 at 10:49 (399 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
