Thread Number: 92997
Found! I found this vintage GMH Frigidaire washer!! |
Post# 1175916   3/25/2023 at 00:14 (406 days old) by Smartdrive1100 (Melbourne, Victoria, Australia)   |   | |
After a few years of searching, I finally found a Frigidaire made by GMH, it is just the deluxe model!!
I am so happy to finally get my hand on one of these. It was sitting in a barn for who knows how long so it has its issues and I need help fixing them. First problem is rust(to be expected) I probably can sort that out on my own Second issue, it won’t spin, it agitated just fine but spinning it turns a little and the agitator moves a bit but it just stops, seems like a stuck brake from sitting for a while, any help would be appreciated. |
Post# 1175922 , Reply# 1   3/25/2023 at 02:25 (406 days old) by qsd-dan (West)   |   | |
Post# 1175928 , Reply# 2   3/25/2023 at 04:05 (406 days old) by Smartdrive1100 (Melbourne, Victoria, Australia)   |   | |
Forgot to mention that, it’s a multimatic.
I did fix it, didn’t need any pulling apart! I noticed the tub had moved a bit from when I turned it on to spin so whilst the motor was humming I spun the tub with my hands and boom! It had freed itself and span up! Was a bit leaky so definitely needs to get the rust sorted… |
Post# 1175970 , Reply# 3   3/25/2023 at 06:48 (406 days old) by gizmo (Victoria, Australia)   |   | |
Photo please!
My family had one of those when I was a kid - a Deluxe Multimatic with the beige painted dashboard.
I'm excited for you.
You know these were made at the Holden factory in Dandenong, don't you? |
Post# 1176035 , Reply# 4   3/25/2023 at 15:34 (405 days old) by Smartdrive1100 (Melbourne, Victoria, Australia)   |   | |
It’s in rough shape sadly but I am so surprised to see that it functions properly!
Do you have any memories that you would be keen on sharing? I was talking to my grandmother about this machine a few years back and she said her mother had one! Apparently it shook the whole house whilst it was washing, lol I did know that they were made here at the Dandenong plant, shame it no longer exists :( |
Post# 1176048 , Reply# 5   3/25/2023 at 17:14 (405 days old) by Smartdrive1100 (Melbourne, Victoria, Australia)   |   | |
Post# 1176078 , Reply# 6   3/25/2023 at 22:50 (405 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1176081 , Reply# 7   3/25/2023 at 23:02 (405 days old) by Washerlover (The Big Island, Hawai’i)   |   | |
Post# 1176087 , Reply# 8   3/26/2023 at 01:16 (405 days old) by Smartdrive1100 (Melbourne, Victoria, Australia)   |   | |
Post# 1176099 , Reply# 10   3/26/2023 at 07:47 (404 days old) by Smartdrive1100 (Melbourne, Victoria, Australia)   |   | |
The odd thing I noticed about the multimatics is that the springs that hold the tub up also seems to put tension on the motor for the belts, maybe yours had some sort of defect from the factory? That would explain why the guys couldn’t repair it
I did notice some sort of dial on the back of the washer that had three wires coming out of it (I’ll post a photo tomorrow) and I though maybe that was the speed selector and you had to set it at the back. It might have a new chrome panel but I’m not too sure as everything seems original. Thanks for the kind words |
Post# 1176101 , Reply# 12   3/26/2023 at 07:57 (404 days old) by Smartdrive1100 (Melbourne, Victoria, Australia)   |   | |
I’ve had mine tap the off balance a switch as you can see from the link below but once it got up to speed it was all good, it has a bad spin bearing though so it sounds like a jet (Maytag Neptune flashbacks), so that’ll need attention.
Your older Frigidaire looks really cool, semi automatics are very odd, why couldn’t they have spent the extra few bucks to put a timer in? Shame to hear it’s rusted, I hope nothing is damaged! |
Post# 1176102 , Reply# 13   3/26/2023 at 07:58 (404 days old) by Smartdrive1100 (Melbourne, Victoria, Australia)   |   | |
Post# 1176107 , Reply# 14   3/26/2023 at 09:55 (404 days old) by swestoyz (Cedar Falls, IA)   |   | |
Congrats on your GM/Holden find! It's fascinating to see the hybrid of US inspired parts used on Holden made Frigidaires. The control panel is similar to a 1964 US panel, but the machine top screams 1958 but has a side opening lid, which came out in '60.
Multimatics sadly do not age well and the longer they sit the worse off it can be. With time and moisture intrusion, the brake lining can get stuck to the brake housing, causing catastrophic damage when the machine is put into spin for the first time and the machine attempts to engage the brake. Does the tub coast at all during spin or does it try to start up and eventually the thermal protector in the motor shuts the machine off? Is the motor humming like it's stuck? Can you manually turn the tub by hand clockwise, against the brake? It is possible to replace the upper bearing without disassembling the entire machine and mechanism. Check out the link below, where I had to change out the upper bearing on the '61 clamshell. www.automaticwasher.org/c... The motors on these are also quite special and it appears to be an original GM Delco. The spring attached to the side is the counter balance spring that helps keep the assembly centered and would have no impact on the overall function. Ben |
Post# 1176220 , Reply# 15   3/27/2023 at 02:25 (404 days old) by Smartdrive1100 (Melbourne, Victoria, Australia)   |   | |
It is spinning and stopping ok after I gave it help.
I’ve pulled it apart and it’s pretty rusty, I have no welding experience at all but I do know people with welders. What would be the best solution to tackle this with? The rubber ring at the top of the tub is also shot. |
Post# 1176272 , Reply# 17   3/27/2023 at 20:37 (403 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1176278 , Reply# 18   3/27/2023 at 21:25 (403 days old) by swestoyz (Cedar Falls, IA)   |   | |
Callan,
Thank you for posting the additional photos. It is fascinating to see how these were constructed under the outer cabinet, which is completely foreign to a US made Frigidaire washer. It appears the outer tub is bolted to a frame that looks very similar to a solid tub Norge or Kelvinator frame. How cool! As for the areas along the upper ridge that have rusted away - there are a few options. You could try using a patching material, say some plastic from a container that is bound for recycling, and trimming a strip to cover the area and using either an RTV or epoxy to fasten it to the outer tub. Or, a filler like JB Weld could be used to build up material that you can then sand down to the contour of the tub. Lastly, I'd also recommend using an epoxy paint or POR-15 to treat the rust metal. The areas around the bottom rim may be hinting to additional rust on the inside of the tub. Good luck and I'll be curious which route you end up taking to get this very rare appliance up and running with confidence, again! Ben |
Post# 1177664 , Reply# 19   4/9/2023 at 06:45 (391 days old) by Smartdrive1100 (Melbourne, Victoria, Australia)   |   | |
