Thread Number: 93088
Magic Chef .9 cu/ft Washer |
Post# 1177197   4/4/2023 at 22:01 (389 days old) by pumper (SE Wisconsin)   |   | |
I picked this up at a yard sale recently. When washing, the impeller will mostly only rotate counter-clockwise. You can hear the motor as if it's trying to alternate both directions. If I turn the tub manually, it will work properly for a short time but then start only one direction again. I found this spring in the bottom of the cabinet but I don't see an obvious place to put it nor do I even know if this spring belongs on the machine. Anyone with one of these have any insight?
Post# 1177217 , Reply# 1   4/5/2023 at 07:25 (389 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1177224 , Reply# 2   4/5/2023 at 10:01 (389 days old) by pumper (SE Wisconsin)   |   | |
I just found on the Magic Chef site that it's called a twist spring so it must go somewhere under here. It's too big to be from a clothespin.
CLICK HERE TO GO TO pumper's LINK |
Post# 1177229 , Reply# 3   4/5/2023 at 11:56 (388 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1177248 , Reply# 4   4/5/2023 at 20:24 (388 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1177368 , Reply# 5   4/6/2023 at 21:28 (387 days old) by pumper (SE Wisconsin)   |   | |
