Thread Number: 93100
/ Tag: Modern Dishwashers
kenmore dishwasher model# 630-13902011. |
Post# 1177329   4/6/2023 at 15:22 (387 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Hey guys. Has anybody tried this dishwasher? What did you like or dislike? CLICK HERE TO GO TO GELaundry4ever's LINK |
Post# 1180068 , Reply# 2   5/7/2023 at 20:16 (355 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I am actually going to check out the dishwasher as I move into my apartment. Question does it have a vertical or horizontal pump module? Also, how often do they cavitate during the wash cycle? |
Post# 1180091 , Reply# 3   5/8/2023 at 10:18 (355 days old) by rinso (Meridian Idaho)   |   | |
I had a Kitchen Aid clone Kenmore Elite. It never dried very well, but it did a good job of cleaning. After 6 years its main motor failed. I replaced it with a TOL Kitchen Aid. It doesn't dry very well either. |
Post# 1180313 , Reply# 6   5/10/2023 at 22:30 (352 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I noticed that my dishwasher doesn't have a sanitize option button. How do I activate the sanitize option? The manual doesn't make it easy. |
Post# 1180320 , Reply# 7   5/11/2023 at 00:06 (352 days old) by DADoES (TX, U.S. of A.)   |   | |
The Pots & Pans cycle meets NSF (National Sanitation Foundation) requirements. It's the only choice for Sanitize. There's no separate Sanitize option available for other cycles. The Sanitized light on the display will illuminate when the cycle is complete if the required temperature is attained and held for the required amount of time. The manual advises that the Sanitized light may fail to illuminate if the water supply temperature is too hot, which reduces water heating time and shortens the exposure time of the load. Sanitizing involves not only the temperature of the water but also the length of time to which the dishware is exposed to the high-temp water. |
Post# 1180341 , Reply# 8   5/11/2023 at 09:27 (352 days old) by nmassman44 (Brooksville Florida)   |   | |
That dishwasher is built by Bosch. The only cycle that has any sanitizing is the Pots and Pans cycle since it gets the wash portion up to 160F and the final rinse as well. I had a Bosch dishwasher that was here in the house that we live in here in FL and it did a decent job but my gawd was lacking in capacity and tine spacing for plates. But that said this dishwasher does NOT use all arms at once to clean the load. It will alternate between the lower and upper arms and on occasion the top shower. One thing is make sure that the filter is cleaned every month and use a toothbrush to get between the folds of the fine mesh screen. The other thing is that this dishwasher, or at least the Ascenta Bosch that I had , is that if one has chunky dishes like thick plates the tines are not forgiving , Corelle plates do quite well here since they are thin.
The Bosch that I had had the plastic sump area that was mated to the stainless steel part of the tub. There was no base pan in the one I had which kinda of surprised me when I took it out to install the current LG dishwasher that resides there now. The LG holds quite bit more and has more features that I love and everything comes out spotless. |
Post# 1180352 , Reply# 9   5/11/2023 at 13:25 (352 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
What is the configuration of this pump? Is it vertical or horizontal? Also, is it single or variable speed? And finally, does it run all arms simultaneously or do they alternate? |
Post# 1180353 , Reply# 10   5/11/2023 at 13:31 (352 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I have the spray arm question answered. The question is, which arm does it start with first during operation? What's the sequence? |
Post# 1180706 , Reply# 12   5/15/2023 at 21:11 (347 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
So far, I ran 2 loads of dishes, and I will run the last one. I used smart wash and turbo clean. I noticed that the turbo clean runs the pump at full force for a longer period of time. |
Post# 1180765 , Reply# 13   5/16/2023 at 16:28 (346 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
The maintenance man finally put brand new wheels on the bottom rack. Now it glides nice and smooth. |
Post# 1180886 , Reply# 14   5/18/2023 at 00:00 (345 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I have to say that the dishwasher got everything cleaned. |
Post# 1181435 , Reply# 15   5/28/2023 at 23:01 (334 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I did find the user's manual online, and I have to say it was very easy to use. What I'm trying to figure out is what arm operates first. To me, it sounds like the arms all operate at once. CLICK HERE TO GO TO GELaundry4ever's LINK |
Post# 1181436 , Reply# 16   5/28/2023 at 23:10 (334 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Here's the actual user's manual. I noticed how it says the turbo clean option is for the lower rack. I'm wondering if this stays at the full pressure constantly during the cycle. CLICK HERE TO GO TO GELaundry4ever's LINK |
Post# 1187549 , Reply# 18   8/14/2023 at 06:41 (257 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Where was this dishwasher manufactured? |
Post# 1189099 , Reply# 19   9/1/2023 at 16:05 (239 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Post# 1189100 , Reply# 20   9/1/2023 at 16:17 (239 days old) by Gelaundry4ever (Nacogdoches, TX, USA)   |   | |
Here's a picture of the dishwasher. I hope the picture is clear enough to see. |
Post# 1189101 , Reply# 21   9/1/2023 at 16:24 (238 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Post# 1189103 , Reply# 22   9/1/2023 at 16:46 (238 days old) by Gelaundry4ever (Nacogdoches, TX, USA)   |   | |
Here are pictures of the dishwasher. |
