Thread Number: 93145
LA612 lip seal |
Post# 1177873 , Reply# 1   4/11/2023 at 16:23 (388 days old) by Thatwasherguy (Kentucky)   |   | |
When I rebuilt the transmission in my 1978 Maytag, I ordered both seals, thinking I could use the lip seal as well as the O-ring. I found out very quickly that this is not the case. On the pre 1986 transmissions, there is no slot for the lip seal, just a groove in the lower housing for the O-ring. When replacing the O-ring, patience is key. Be prepared to spend about 20 mins with a VERY steady hand and a pick set to maneuver it into the groove, while not scratching the housing in the process. Good luck on your repair!
Thatwasherguy. |
