Thread Number: 93158
Repeated Suds locking and Electric smells |
Post# 1178030 , Reply# 1   4/13/2023 at 17:00 (379 days old) by Mrlaundry1011 (South Wales, UK)   |   | |
Sounds like the air vent for the drain is clogged and/or the hoses connecting it |
Post# 1178033 , Reply# 2   4/13/2023 at 18:07 (379 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 1178036 , Reply# 3   4/13/2023 at 18:15 (379 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Is your outlet 50 or 60 hertz? Just curious. |
Post# 1178055 , Reply# 4   4/13/2023 at 22:16 (379 days old) by Maytag85 (Sean A806)   |   | |
Post# 1178081 , Reply# 6   4/14/2023 at 03:50 (379 days old) by mieleharrison (Empingham, Stamford)   |   | |
Thanks for all the help.....The shocks are in dire need of replacement and I guessed id need to take hoses apart... so I can kill 2 birds with one stone! (Not sure of the frequency - apologies) Thanks for all the replies!! Really Appreciate it! |
Post# 1178084 , Reply# 7   4/14/2023 at 05:05 (379 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Morning Harrison, you just worked out your own theory !!
On these models when the shocks are worn the bottom of the drum vibrates up and down too fast for the water to escape completely through the Detergent Recovery nozzle , so air is being drawn into it which before the water has had chance to escape, computer thinks sump is empty and proceeds to spin and so water / sudz lock begins. Change the shocks and it should sort itself straight away , the other thing you can do is when next changing the sump hose remove the floating white plastic ball from the plastic fixture (keep the fixture in place for the integrity of the sump hose wand water exiting ) so the water flows through the sump with greater force, if you place the powder onto the clothes water has filled the sump so no detergent loss etc, a few members spoke of doing this and it works etc |
Post# 1178087 , Reply# 8   4/14/2023 at 06:31 (379 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
We have 120/240 v, 60 hz here in the US. |
Post# 1178185 , Reply# 9   4/15/2023 at 08:16 (378 days old) by gizmo (Victoria, Australia)   |   | |
Frequency? - A Google search reveals that Empingham and Stamford are in the UK, so are 230V 50HZ. |
