Thread Number: 93240
Wiring Diagrams for Whirlpool Washers |
Post# 1178834 , Reply# 1   4/23/2023 at 09:22 (370 days old) by chetlaham (United States)   |   | |
Service Matters used to be open to the public, but somewhere in 2007 some type of ultra backwards conservative thinking lead to Whirlpool requiring you to pay and register as a service tech to view what ought to be not only free but in every owners packet that comes with a machine.
Google images has some generics that are very similar to most Whirlpool models already in existence. If you have the machines in person the wiring diagram should be glued to the back of the control console or as a piece of paper folded up in the back of said console.
You can also try asking on an appliance repair site. They will often give you the PDFs is you tell them you've diagnosing these two machines for some obscure electrical problem.
I feel your frustration though. I've built a few franken machines in the past. Plus, before I use or buy any appliance I have to see the tech sheet first. No tech sheet no buy. If I don't see mathematical elegance whilst respecting traditional values it ain't happening either.
Post# 1178854 , Reply# 2   4/23/2023 at 13:58 (370 days old) by maranoman (Des Moines, Iowa)   |   | |
LSR8200EQ0 is first and LLR9245BQ1 is second. These came directly from ServiceMatters - I have a subscription.
- Jeff |
Post# 1178858 , Reply# 3   4/23/2023 at 14:30 (370 days old) by chetlaham (United States)   |   | |
Post# 1178876 , Reply# 5   4/23/2023 at 17:45 (370 days old) by chetlaham (United States)   |   | |
Post# 1178888 , Reply# 6   4/23/2023 at 19:58 (370 days old) by maranoman (Des Moines, Iowa)   |   | |
Post# 1178925 , Reply# 7   4/24/2023 at 04:51 (370 days old) by chetlaham (United States)   |   | |
Post# 1178933 , Reply# 8   4/24/2023 at 08:15 (370 days old) by maranoman (Des Moines, Iowa)   |   | |
Post# 1178944 , Reply# 10   4/24/2023 at 10:51 (369 days old) by chetlaham (United States)   |   | |
Post# 1178945 , Reply# 11   4/24/2023 at 10:54 (369 days old) by chetlaham (United States)   |   | |
Post# 1178960 , Reply# 12   4/24/2023 at 12:44 (369 days old) by maranoman (Des Moines, Iowa)   |   | |
@chetlaham: I was able to find a wiring diagram and parts list for HDA460-03 AD.
I tried sending them to your gmail account listed under your member profile, but it failed saying that email address no longer exists. You can send me an email to my member profile email and I will reply back with the parts list and wiring diagram. This post was last edited 04/24/2023 at 13:13 |
Post# 1178966 , Reply# 13   4/24/2023 at 13:40 (369 days old) by chetlaham (United States)   |   | |
Post# 1178992 , Reply# 14   4/24/2023 at 16:52 (369 days old) by DADoES (TX, U.S. of A.)   |   | |
A 3-speed WP model I have with a separate speed control switch has a timer shift to low speed toward end of the Normal cycle wash period and ex-low on Casual/Perm Press. A momentary power break occurs at the moment of change but not a full motor stop. The change may be up or down or no change depending on what is the selection on the speed switch. See video first below at 10:05 for an example of no change on the Normal cycle (low before and after). My 1991 KitchenAid 3-speed (no separate speed switch) with Stepped Spin does not pause the motor when changing speeds during the spin periods. Perm Press final spin runs 2 mins each of all three speeds increasing in succession. Also the 1994 model my parents had. KA models with Stepped Spin are the only direct-drives I've seen that run spin at the ex-slow speed. See the second video below (done years ago) for my KA changing spin speed (with a forced spin-drain) on Perm Press at 0:24 and 2:24. The KA, interestingly, does pause when changing agitation speed, low motor to ex-low motor. See 3rd video below, 0:45. |
