Thread Number: 93266
Revolutionary idea to replace concrete |
Post# 1179246   4/27/2023 at 17:53 (366 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 1179250 , Reply# 1   4/27/2023 at 18:07 (366 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1179274 , Reply# 2   4/28/2023 at 04:53 (365 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 1179276 , Reply# 3   4/28/2023 at 07:27 (365 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
My brother Jeff and I talked about this 25 years ago, on our design the cold water would fill through the ballast tank so it would fill automatically the first time you started the machine.
Of course Whirlpool uses plain water in the ballast rings on their TL washers for over 30 years so there is no concrete to cause extra emissions.
The world's best FL washer for home use Speed Queen uses cast iron for its ballast weight, Cast Iron will last much longer without cracking and is fully recyclable when the washer reaches the end of its life.
Post# 1179362 , Reply# 6   4/29/2023 at 06:25 (364 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
yes indeed it was a key part of the Reason washing machine produced 2005 but never made it into production .
The balaast tank was underneath as well as weight above , the tank filled from mains water then for wash was pumped into the drum so warming the water from cold, then repeat each fill.
Post# 1179597 , Reply# 7   5/2/2023 at 01:47 (362 days old) by mielerod69 (Australia)   |   | |
V-Zug's balancing system uses water to smooth out imbalances during the spin cycle. The water is then drained into the drum to use for the rinse cycles.
CLICK HERE TO GO TO mielerod69's LINK |
Post# 1179601 , Reply# 8   5/2/2023 at 04:23 (361 days old) by ozzie908 (Lincoln UK)   |   | |
