Thread Number: 93301
Were there issues with these? Kenmore 90 Series Plus |
Post# 1179692   5/3/2023 at 13:00 (366 days old) by BlockEight88 (Hobart, IN)   |   | |
I have been on the lookout for a Kenmore 90 Plus Series with the triple dispensers. It seems these are somewhat difficult to find. I read somewhere (may have been on this site) that these were only made for a short time (around 1997) and then production ceased. Does anyone have any insight as to why that may or may not have been the case?
These washers appear to be top of the line with the Quit Pak Plus and Triple Action Agitator. Thanks |
Post# 1179852 , Reply# 1   5/4/2023 at 19:55 (365 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1179858 , Reply# 2   5/4/2023 at 20:41 (365 days old) by chetlaham (United States)   |   | |
Post# 1179864 , Reply# 3   5/4/2023 at 21:29 (365 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1179865 , Reply# 4   5/4/2023 at 22:04 (365 days old) by chetlaham (United States)   |   | |
Post# 1179909 , Reply# 5   5/5/2023 at 15:08 (364 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1179929 , Reply# 6   5/5/2023 at 20:54 (364 days old) by chetlaham (United States)   |   | |
Post# 1179932 , Reply# 7   5/5/2023 at 21:24 (364 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1179950 , Reply# 8   5/6/2023 at 09:47 (363 days old) by philcobendixduo (San Jose)   |   | |
.....washer has the triple dispensers and they still work just fine. I've never had any issues with them other than some water being left in the bleach dispenser on occasion.
I always dry them out when I'm done using the machine by stuffing a small fingertip towel in the bleach and fabric softener dispensers and letting it soak up any residual water. i then remove the towel and leave the lid of the machine open so it can dry out. I also remove the liquid detergent dispenser and put it upside down on the agitator so it can dry out as well. I rinse it under the fill water when I'm doing the last load of the day (after it's done dispensing the detergent). |
Post# 1179952 , Reply# 9   5/6/2023 at 09:55 (363 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1179979 , Reply# 10   5/6/2023 at 17:58 (363 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
These dispenser systems worked very well, but it’s a lot of extra complication. There’s four extra inlet valves alone.
There are chances for leaks and failures, I like these systems however, considering how much of a perfectionist you are, I might avoid them. I’m sure you can find there are flaws in them as the previous poster mentioned where you have to do the extra dry them out, etc.. John |
Post# 1179984 , Reply# 11   5/6/2023 at 18:27 (363 days old) by BlockEight88 (Hobart, IN)   |   | |
Thank you for your insight, John. Sometimes we need to hear the obvious. I am indeed a perfectionist when it comes to these machines. I was just curious though because from what I read they weren’t on the market very long. Maybe someone could correct me on this? Probably best just to stick with what I have which is a Kenmore ultra Fabric Care from 1994 and a Kenmore elite from 2002 both work about as good as they’re going to get I’ll probably just set my sights on finding a matching Kenmore elite gas dryer
Post# 1180001 , Reply# 12   5/6/2023 at 22:27 (363 days old) by DADoES (TX, U.S. of A.)   |   | |
A similar dispensing trio was used on the Calypso and Catalyst models and some top-of-line KitchenAids. The water valves are the kind of model-specific part that goes NLA sooner than the more common mechanical items. The Calypso and Catalyst valve assemblies have six solenoids: hot and cold incoming, and output ports for tub fill/spray, detergent flush, bleach flush, and softener flush. John says the Kenmore of question has four extra valves so is the same. |
