Thread Number: 93400
/ Tag: Vintage Dishwashers
GE 2800 |
Post# 1180774   5/16/2023 at 19:45 (353 days old) by jil1000 (Northern CA )   |   | |
Post# 1180778 , Reply# 1   5/16/2023 at 19:53 (353 days old) by appnut (TX)   |   | |
Post# 1180779 , Reply# 2   5/16/2023 at 20:07 (353 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1180790 , Reply# 3   5/16/2023 at 21:49 (353 days old) by MattL (Flushing, MI)   |   | |
Had one for many years at the time it was one of the best performers. Lots of options and neat features.
That said, performance wise my current KA cleans rings around all the DW's I've owned. |
Post# 1180791 , Reply# 4   5/16/2023 at 21:50 (353 days old) by Cam2s (Nebraska)   |   | |
The electronics can be dodgy as they age but if it’s barely been used I’d say it would be worth it. My Potscrubber has the same racking and Wash system and is excellent. |
Post# 1181313 , Reply# 6   5/26/2023 at 10:15 (344 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Most important thing to do if you have one of these that you want to actually use his to replace the motor with the new high-efficiency motor. Otherwise the draw from the old black motor tends to ruin the boards.
If you wanted to keep the original motor and all the inherent noise and heat output, put a relay on it so that you don’t damage the circuitboard. I have seen many of the GSD 2800 and the similar 25, 2600 models burn up the boards on the motor contacts. John. |
Post# 1181314 , Reply# 7   5/26/2023 at 12:03 (343 days old) by rinso (Meridian Idaho)   |   | |
We had one in the last half of the 80's. It was one of the best dishwashers we've owned, along with our non-reverse rack Maytag in the 90's. |
Post# 1181326 , Reply# 8   5/26/2023 at 17:01 (343 days old) by marky_mark (From Liverpool. Now living in Palm Springs and Dublin)   |   | |
It is just the motor that poses a risk to the board or does the 900-Watt heater in my GE2800 also draw power through the board with no relay?
I did replace the pump pretty much as soon as I got the machine, even though it was working fine. The electronics on mine have always behaved 100% perfectly and correctly, so far!
Mark |
