Thread Number: 93403
/ Tag: Vintage Dryers
Help me keep my Avocado Lady Kenmore going! |
Post# 1180830 , Reply# 1   5/17/2023 at 06:20 (353 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1180831 , Reply# 2   5/17/2023 at 06:30 (353 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This is one of my favorite dryers, not only was it an all new design, but it was very reliable and great performer.
That said you probably have either a bad, electronic control or power relay. Neither part would be easily available. I may have good used ones if needed The power relays in the control panel need to check the coil for continuity. You can also hotwire it and see if it works if it’s not that it’s the electronic control. Do you try running it on the air fluff cycle it should run about 10 minutes or so if that works it’s not the sensor. John. |
Post# 1180835 , Reply# 3   5/17/2023 at 10:59 (352 days old) by Ahagey (Pontiac, MI)   |   | |
It does the same thing when set to air fluff or heat. |
Post# 1180836 , Reply# 4   5/17/2023 at 11:32 (352 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1180885 , Reply# 5   5/17/2023 at 23:41 (352 days old) by Ahagey (Pontiac, MI)   |   | |
Thanks for the direction. I’ll see if I can get it apart and find out more this weekend. I’ll report back when I do. Thanks! |
Post# 1181044 , Reply# 6   5/20/2023 at 20:41 (349 days old) by ahagey (Pontiac, MI)   |   | |
Combo, do you have a good used electronic control? And what would you charge for one? |
Post# 1181079 , Reply# 7   5/21/2023 at 06:05 (349 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
