Thread Number: 93466
Maytag A106 - Slow Agitation |
Post# 1181407   5/28/2023 at 13:08 (341 days old) by drummerboy928 (Illinois)   |   | |
Hello all, I have a relatively small question to ask for today. I ran the first load of laundry through my 1969 Maytag A106 today, and noticed it seemed to be agitating rather slowly. Without clothes in it, it starts off agitating rather slowly but picked up to full speed in a couple seconds. I’m thinking it may be a worn out belt.
I lubricated the motor slides too, but thought I should at least ask some experts their thoughts on it before I made any purchases. Is anyone able to confirm or deny my thoughts on a worn belt being the issue? -Henry CLICK HERE TO GO TO drummerboy928's LINK |
Post# 1181410 , Reply# 1   5/28/2023 at 13:44 (341 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Have you tried removing the front panel and using the toe of your shoe to pull the motor back in its carriage while the machine is agitating to see if that speeds up the agitation? You might have over-lubricated things. |
Post# 1181414 , Reply# 2   5/28/2023 at 15:49 (341 days old) by Maytag85 (Sean A806)   |   | |
Post# 1181415 , Reply# 3   5/28/2023 at 15:54 (341 days old) by drummerboy928 (Illinois)   |   | |
This problem was popping up before I lubricated the motor slides. When I pushed the motor back (before I lubricated) it would increase the speed. My thoughts were that since the motor slides were basically dry, it wasn’t able to slide all the way back and tension correctly. However the problem persisted after I lubricated. I made sure to wipe off any excess before it made its way to the belt.
Post# 1181735 , Reply# 4   6/3/2023 at 13:37 (335 days old) by Mayken4now (Panama City, Florida)   |   | |
Henry,
Have worked on MANY of those types of Maytag machines. Helical drive transmissions. I have to bust your bubble. The transmission has old oil in it (it turns very thick and is almost like grease). The warmer the transmission is, the more speed the agitator gains. Needs to be taken apart, cleaned thoroughly. I have used mineral spirits to make sure all old oil has been removed. You will need several parts (NLA) to do this project. It's a complete tear down and put back together. --Steven |
Post# 1181747 , Reply# 5   6/3/2023 at 16:12 (335 days old) by RyneR1988 (Indianapolis)   |   | |
Henry,
Does your Maytag washer make like a grinding, scraping sound when it first starts up agitating? When I had one of these washers for a short time, it did this and the noise would go away as agitation picked up speed. I never did figure out what the issue was because the machine started leaking, and given that my wife and I are both disabled, I decided to get rid of it before the problem got worse. I was given the washer for free after my VMW died, so no harm, no foul, and we got a Whirlpool direct drive instead. Hopefully you can figure this out. Ryne |
Post# 1181770 , Reply# 6   6/3/2023 at 19:36 (335 days old) by drummerboy928 (Illinois)   |   | |
I was thinking that the gear oil had at least thickened somewhat but I am not entirely convinced it is 100% the issue at hand. A week prior to posting this (2 weekends ago), I had run an empty cycle with just a full tub of water. The machine started off slowly, but in about 4 seconds had picked up to full speed and continued to stay the same speed and operate as normal. However, once it came time to run a load (1 bath towel, 1 shirt, and 1 pair of pants) (1 weekend ago), the machine seemed sluggish. It agitated very slowly at first, and only picked up a little speed on its own. However when I nudged the motor, it picked up to speed perfectly fine. Then when it came time to spin, it didn’t seem like it wanted to get up to full speed, or at least took a bit longer than I would’ve thought with a load that light. I’m definitely thinking more towards the belt, and will try swapping the belts for it with one of my other Maytags to see if that makes a difference this weekend. I would’ve tried that last time but I did not have a lot of time and didn’t think of it at that point.
Post# 1181780 , Reply# 7   6/3/2023 at 23:47 (335 days old) by qsd-dan (West)   |   | |
If the washer is sluggish on the spin cycle, the problem is one or a combination of....
Worn belts.
Worn/missing rollers/glides on the motor carriage tracks.
Dirty motor carriage track(s) (For the love of God, do NOT use oil to lubricate them).
Weak or stretched out motor carriage springs.
Pump bearing seizing up.
Pump belt tension adjusted too tight.
Dirty/oily belt pulley(s). Use brake cleaner.
Tub bearing may be seizing up but it'll let you know audibly.
Motor crapping out (it doesn't sound right in your clip). |
Post# 1182042 , Reply# 8   6/7/2023 at 19:30 (331 days old) by cadman (Cedar Falls, IA)   |   | |
Dollars to donuts it's old, congealed oil. And as mentioned above, it's a full teardown to get the trans apart to drain and fill. I did this job an an 806 of mine that's been a daily driver for years, but when winter would hit, agitation was pathetic. I replaced the oil with Redline MT-90 and it's night and day. Temp makes practically zero difference now. Video below.
Now I'm wondering if there's a spot on the trans where a guy could safely drill a hole to drain, thread with a tap, refill and plug. Might be worth investigating. CLICK HERE TO GO TO cadman's LINK |
Post# 1182044 , Reply# 9   6/7/2023 at 19:37 (331 days old) by qsd-dan (West)   |   | |
Post# 1182063 , Reply# 10   6/7/2023 at 23:48 (331 days old) by Good-Shepherd (New Jersey)   |   | |
It the trans oil has thickened to the point where it affects agitation good luck trying to drain it. That stuff is like molasses, even using gasoline it takes some elbow grease to get it all cleaned out. |
Post# 1182080 , Reply# 11   6/8/2023 at 12:23 (330 days old) by Mayken4now (Panama City, Florida)   |   | |
Post# 1182856 , Reply# 12   6/18/2023 at 11:39 (320 days old) by drummerboy928 (Illinois)   |   | |
I did some testing this weekend. I am beginning to believe that a seizing pump may be the issue with why it takes a while to spin up to speed. With the pump belt on, after a minute it never felt like it got to full speed, while with the pump belt off, the machine seemed to spin up to full speed in about 40 seconds, give or take. On these old style pumps, is there a way to oil them or free them up, by removing the screw in the side, or would I need to put in a new pump? I’d love to keep the original two piece pump in, but if not, I would just have to deal with it. As for the agitation, I have not gotten that figured out yet, but I think it may be a combination of 50+ year old transmission oil, the pump issue, and old belts. Any help or advice is greatly appreciated!
-Henry |
Post# 1182858 , Reply# 14   6/18/2023 at 11:50 (320 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1182859 , Reply# 15   6/18/2023 at 12:01 (320 days old) by drummerboy928 (Illinois)   |   | |
Thank you for your quick replies. At this point I am feeling 99% confident that all the issues with it spinning slow and agitating slow are caused by the pump beginning to seize. With the pump belt removed, the washer agitates perfectly, and spins well too. Once the pump belt is put back on, the spin starts to feel slow, and the machine struggles to agitate. I will attempt to add some oil to the pump bearing, and if that doesn’t fix it, make the call and put a new pump in the machine.
Post# 1182861 , Reply# 16   6/18/2023 at 12:05 (320 days old) by qsd-dan (West)   |   | |
Did the start capacitor blow up during the agitation or spin cycle?
Sluggish agitation is caused by many things as I pointed our earlier in this thread. Everybody is looking for an easy fix without putting in any time and effort getting dirty and learning how make these machine run properly. If this is you, sell it and go buy a new front loader.
Time is running out and parts are quickly drying up and it's only going to get more difficult. Either get busy properly fixing these washers now before it's impossible to do so or stop wasting your time with them and go buy something new. |
Post# 1182863 , Reply# 17   6/18/2023 at 12:28 (320 days old) by drummerboy928 (Illinois)   |   | |
taking the pump out of the equation definitely improved the situation, especially with the spin, which is why I believe that it’s at least part of the issue at hand. I fully intend to replace the oil in the transmission at some point, but in the meantime, I don’t have the time to set aside to doing it, so that will be a project set on the back burner for now, until I get a large chunk of time I can spend working on it, and am able to find and get a hold of all the parts I need to do it. I do want to learn and get better at being able to take care of these machine as well as keep them running for as long as I can.
Post# 1182865 , Reply# 18   6/18/2023 at 13:10 (320 days old) by drummerboy928 (Illinois)   |   | |
Post# 1182871 , Reply# 19   6/18/2023 at 15:25 (320 days old) by DADoES (TX, U.S. of A.)   |   | |
Have you confirmed the pump belt is at correct adjustment? It's looser than may be expected. Take off the front panel and pull the motor forward so the transmission belt is at full tension with the carriage springs, release it. With the machine properly upright (not leaned back, so the weight of the motor doesn't work against the carriage springs), reach beneath and squeeze the pump belt together in the middle between the pulleys. The motor carriage should not move until 1/4" space between the pump belt loop. The pump belt is too tight if the motor moves at more than 1/4" gap.
Post# 1182880 , Reply# 21   6/18/2023 at 17:40 (320 days old) by drummerboy928 (Illinois)   |   | |
I checked the belt tension and it seemed a tiny bit over tensioned. I loosened the tension to be within specification, but it did not seem to change the way the machine behaved much if at all. However, how freely should the pump spin? When I try and turn it by hand, it seems to stop very quickly, and seems to be "tight" if that makes sense. It doesn't seem to bind, but it does not spin without a little bit more force than I would think it should take. I will be out of the state this coming week, but what should I use to oil/lubricate the pump and see if it frees up any?
Post# 1182888 , Reply# 22   6/18/2023 at 19:25 (320 days old) by qsd-dan (West)   |   | |
I've successfully freed up most pumps that were getting tight/seizing up by lubricating them with turbine oil but there was a couple of situations where the damage was permanent and no amount of oil was going to fix them. It's very difficult to explain over the internet about the proper drag these bearings have when the pulley is spun. It should be very easy to turn with no rough spots but these don't contain roller bearings that keep spinning when the pulley is spun with the flick of a wrist....if that makes any sense. |
Post# 1184030 , Reply# 23   7/2/2023 at 23:37 (306 days old) by drummerboy928 (Illinois)   |   | |
After longer than I anticipated, I’m finally back home and able to put some more into this thing. As far as lubricating oil, I’ve heard good things about Zoom Spout turbine oil. Should I go for that, or is there a different, recommended brand?
However I intend to, eventually, go through this machine right. I’ve been going through and finding parts I will need for when the time comes and I can rip this thing apart and change the trans oil. So far I’ve been able to find 203956 - Damper pad kit 6-2040130 - Tub Bearing Kit 6-2095720 - mounting stem/tub boot kit 205000 - motor spring and slide kit A) are these all the correct parts and part numbers needed for this washer, but also B) what else will I or might I need when going through this machine. If I’m going to be going super deep into this, it’s going to be the furthest I’ve gone into one of these Maytag’s, so I’m not sure about a lot of the things I May have to replace. Any help is great :) - Henry |
Post# 1184036 , Reply# 24   7/3/2023 at 02:40 (306 days old) by qsd-dan (West)   |   | |
If you are going to go that far into it, you might as well crack the transmission open and get that old oil out of there which is probably dragging its speed down. Also, replace the lower o-ring that WILL leak, if it isn't leaking already (I'm sure its). You'll need a pick set it remove and install the o-ring. It's up to you if you want to replace other parts since they're getting hard to find. When I crack a trans open, I replace the Delrin pinion gear, both clutch washers, and the lower o-ring. I also disassemble the upper trans housing but I would not recommend doing that since it's very involved and getting the groove pin out is a royal PITA. The groove pin is almost impossible to find now. Just flush the upper housing out the best you can through orifice in the housing.
I'd also add the older A4298 seal and install it under the triple lip seal as insurance.
The transmission top gasket is impossible to find now but you can use a good quality Permatex gasket sealer as a replacement. I used Toyota FIPG on my daily driver almost 15 years ago when the new trans gasket fell into the new oil and I didn't want to order and wait for another gasket to arrive. Still 100% leak free.
As far as the pump goes, Zoomspout turbine oil is the only oil that will pour through the very tiny orifice. You won't be able get a thicker non detergent/non paraffin oil in there such as the blue can of 3 in 1 without making a total mess of things.
Not sure I'd put that much work into a lowly 106 but if you're happy with the machine and want to keep it forever, it's worth the effort. It's definitely a good machine to start out with and learn on, making mistakes along the way. Then you can use your newfound knowledge on nice, higher end machines without fear of messing up/destroying them.
