Thread Number: 93506
Speed Queen TC5000WN: Possible to Skip to End of Cycle? |
Post# 1181739 , Reply# 1   6/3/2023 at 13:51 (329 days old) by appnut (TX)   |   | |
Post# 1181745 , Reply# 3   6/3/2023 at 14:32 (329 days old) by Huebschman (Quebec, CA)   |   | |
I just thanked god for my mechanical timer... :) |
Post# 1181766 , Reply# 4   6/3/2023 at 18:47 (329 days old) by supersurgilator (Indiana)   |   | |
You would be able to run just a spin only cycle, but it would be a high speed spin. |
Post# 1181772 , Reply# 5   6/3/2023 at 21:25 (329 days old) by ladd (Maryland)   |   | |
I tried a Spin cycle only, but when I attempted it earlier today the tub filled with water for a few seconds (it was already full), then agitated at full speed which is not what I wanted. I'll see if that behavior happens again. |
Post# 1181773 , Reply# 6   6/3/2023 at 22:18 (329 days old) by WindRivers (Wind River Range, WY)   |   | |
When you just want it to spin, make sure you don't have extra rinse selected when you select the spin cycle. When both are selected it will fill, rinse, and then spin. |
Post# 1181782 , Reply# 7   6/4/2023 at 03:47 (329 days old) by Aquarius1984 (Planet earth)   |   | |
Post# 1181794 , Reply# 8   6/4/2023 at 09:33 (328 days old) by ladd (Maryland)   |   | |
> When you just want it to spin, make sure you don't have extra rinse selected > when you select the spin cycle. When both are selected it will > fill, rinse, and then spin. Ahh, that makes sense. Thanks for the tip! |
Post# 1181797 , Reply# 9   6/4/2023 at 09:57 (328 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1181839 , Reply# 10   6/5/2023 at 05:51 (328 days old) by PinkPower4 (USA)   |   | |
See the last row under "Button(s)". If you don't want a high speed spin, this may work?
Post# 1181992 , Reply# 13   6/7/2023 at 07:58 (326 days old) by ladd (Maryland)   |   | |
Wow! I answered my question years ago and have no memory of knowing that information! I'm almost more concerned about my lack of memory than solving this problem! :-) I look forward to trying that method to see if Rapid Advance works. |
