Thread Number: 93556
/ Tag: Modern Dryers
3 wire plug on a newer dryer. |
Post# 1182228 , Reply# 1   6/10/2023 at 17:02 (322 days old) by appnut (TX)   |   | |
Yes, when my Maytag Depenable Care Dry, the 1986 LK, and the new LG dryer all ha to have a similar plug. Look in the installation instructions an you should see how to change the wires going to the terminal for this arrangement. My installers knew what to do.
Congratulations on the house. What year was it built? |
Post# 1182229 , Reply# 2   6/10/2023 at 17:19 (322 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Your dryer is designed for either three or four wire cords, just be sure to get the center wire on the center terminal the other two don’t matter they can be reversed if it happens that way.
There may be a label on the back of the dryer that shows a three and four wire hook ups and instructions surely will if you look at those that came with the dryer or just go online and look at Whirlpools installation instructions. John |
Post# 1182242 , Reply# 3   6/10/2023 at 19:30 (322 days old) by bradfordwhite (central U.S.)   |   | |
You will of course need to turn off the power and change out the 3 wire outlet into the new code compliant 4 wire plug.... or hire an electrician to do it.
The 4 wire cord is pretty easy to install on the dryer. Simply need to attach the green wire to the cabinet screw and install the cord. CLICK HERE TO GO TO bradfordwhite's LINK
Post# 1182276 , Reply# 4   6/11/2023 at 07:48 (321 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1182289 , Reply# 5   6/11/2023 at 12:17 (321 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1182295 , Reply# 6   6/11/2023 at 13:39 (321 days old) by DADoES (TX, U.S. of A.)   |   | |
My house built in 2004 has a 3-prong dryer power receptacle in the laundry room. The extra outlet in the garage is also 3-prong. I've worked on a dryer brought in that has a 4-prong cord. Simple matter to temporarily change the cord for testing the repair, then change it back when done. The dryer doesn't care. |
Post# 1182297 , Reply# 7   6/11/2023 at 13:49 (321 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1182346 , Reply# 8   6/11/2023 at 21:42 (321 days old) by MattL (Flushing, MI)   |   | |
Electrically the 4th ground wire is the same potential as the neutral as they are connected to the same point in the electrical panel. It's there as a safety feature only, stoves and dryers will work fine and safely on a 3 wire circuit. |
Post# 1182388 , Reply# 9   6/12/2023 at 10:44 (320 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Post# 1182402 , Reply# 10   6/12/2023 at 13:44 (320 days old) by bradfordwhite (central U.S.)   |   | |
Dave
dryers are 30 amp double pole and regardless of the 3 or 4 prong plug have one blade that is "L" shaped. Free standing Stoves (with oven(s) and cook top) are typically 50 amp double pole and regardless of the 3 or 4 prong plug do not have an "L" shaped blade. This 4 prong plug is also the same plug used on electric car chargers and RVs/mobile homes with a 50 amp service and flexible cord. I have seen several homes where people have got these plugs mixed up and it causes all kinds of confusion for the home owner.
Post# 1182403 , Reply# 11   6/12/2023 at 14:00 (320 days old) by bradfordwhite (central U.S.)   |   | |
50 amp Electric car charger plug
And just to throw a bit of possible confusion in there... The RV industry (campers/motorhomes/etc) ALSO has a 30 amp/50 amp situation going on. Yes, its models that have a 50 Amp plug uses the same stove plug/car charger plug one can find in their houses. They also have a 30 amp variant however it's a 30 amp SINGLE pole plug that does look very similar to an old style 3 prong dryer plug but there is no "L" shaped blade and the blades are shorter and thinner than a dryer plug. Heaven forbid one should accidently install a 30 amp RV plug onto 30 amp dryer plug wiring. And yes, I've seen this in older camp grounds. |
Post# 1182446 , Reply# 12   6/13/2023 at 00:20 (319 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Whoops I forgot a PICTURE of that actual outlet in my post! —sorry, here it is:
— Dave
Post# 1182447 , Reply# 13   6/13/2023 at 00:35 (319 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1182595 , Reply# 14   6/14/2023 at 16:22 (318 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Not sure really, but definitely before dryers and ranges lost their sheer bulkiness as I’m certain this outlet uses a heavy plug and pigtail…
It was hard to photograph without my shadow hovering over and around and getting excessively in that picture! — Dave
Post# 1182638 , Reply# 15   6/14/2023 at 22:59 (318 days old) by chetlaham (United States)   |   | |
Post# 1182643 , Reply# 16   6/15/2023 at 01:12 (317 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
