Thread Number: 93578
How Do We Feel About The Miele W1 Range? |
Post# 1182364 , Reply# 1   6/12/2023 at 02:05 (321 days old) by mrboilwash (Munich,Germany)   |   | |
In your other thread you mentioned the other Miele skips one rinse when washing at 60 or higher.
My 20 years old Miele is showing signs of failing motor bearings. it could be months or even years but sooner or later I`ll have to buy a new washer. Haven`t made a decision yet because it`s not urgent at all but I think the W1 range does exactly the same thing, reduce the cycle by one rinse at higher temperatures and this would be the greatest deal breaker for me to go with another Miele. |
Post# 1182366 , Reply# 2   6/12/2023 at 02:51 (321 days old) by Logixx (Germany)   |   | |
Hasn't this been a thing with Miele for many, many years? Cotton 60° and above performing two rinses? It is my understanding that this has to do with the temperature-guided sensor rinse. Other have said the reasoning is that a hot wash wouldn't require as much detergent.
I just briefly looked at two W1 manuals and both said that the rinses are reduced - unless you add extra rinse or whatever other option to increase rinsing. |
Post# 1182412 , Reply# 10   6/12/2023 at 17:42 (320 days old) by Stephen (Palm Springs CA USA)   |   | |
I have a WXI860 US version. In the app you can adjust the current levels of TD 1 and 2.
Post# 1184027 , Reply# 12   7/2/2023 at 21:28 (300 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
These are basically a smaller version of the Speed Queen commercial quality front load washers built in the US.
Yes, you can replace the bearings and seals assembly without tearing the whole machine apart. Problem may be is if the shaft is damaged or the seal surface on the shaft is worn to say nothing of the aluminum spider in the Miele That might be corroded and getting ready to break so You still have to take the whole machine apart and replace additional parts. John |
