Thread Number: 93610
Dark Window on New LG Front Load Washer |
Post# 1182689   6/15/2023 at 15:51 (316 days old) by MobileMaid (Huntsville, AL)   |   | |
I recently had to replace my mini LG front load washer. I have very limited space for a stack unit in my 1970's home, and only a 24-inch unit will fit the space.
I bought the LG WM1455HWA from Home Depot and had it delivered a couple weeks ago. The issue I have is that the front door is tinted a very dark color. When the machine is running, you cannot see inside the washer because of the tinted outer glass. I took the door off the machine to see if I could remove the tinted outer glass and it is a "glued" unit that cannot be separated. Any suggestions how to remove the outer tinted glass or replace the door so I can watch my close wash?
Post# 1182703 , Reply# 1   6/15/2023 at 17:53 (316 days old) by seedub (South Texas Hill Country)   |   | |
Same frustration with my Equator. I can darken the light in my kitchen and switch on only the vent hood light. That allows me to see inside. My married friends must switch off the laundry room light and turn on the light in the hallway outside to get optimal vision into their Samsung with a tinted door.
Can somebuddy 'splain the insanity (to me) of installing a window that is barely usable? |
Post# 1182704 , Reply# 2   6/15/2023 at 17:53 (316 days old) by bradfordwhite (central U.S.)   |   | |
1. are you worried that any changes to the machine may invalidate any remaining warranty on it?
2. have you considered simply aiming a light at the door when looking to make it easier to see in? 3. Could you put a water proof camera in the drum some how to get a close up on your phone?
Post# 1182707 , Reply# 3   6/15/2023 at 19:13 (316 days old) by appnut (TX)   |   | |
Timothy, I share your frustration with my WM4200. Member Powerfin64 has a WM4200 and he told me to get a very bright light that shines through the "haze" so to speak. He's not ha any issues once he did that. There's a couple of people on Youtube from Europe that have darkened winow LGs and they manage to film vieos with full cycle lengths. I've not gone out to get a light for myself yet though. And congratulations on the new washer.
Post# 1182711 , Reply# 4   6/15/2023 at 19:43 (316 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1182732 , Reply# 6   6/15/2023 at 23:41 (316 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1182736 , Reply# 7   6/16/2023 at 00:20 (316 days old) by appnut (TX)   |   | |
Post# 1182739 , Reply# 8   6/16/2023 at 03:00 (316 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
The glass is indeed just glued on. Can't attest to the strength of the glue, but the door should have a plastic frame with some screws, and since it's a glass glued onto something else, taking a thin blade between glass and other surface should allow you to cut through the glue. |
Post# 1182740 , Reply# 9   6/16/2023 at 05:20 (316 days old) by mark_wpduet (Lexington KY)   |   | |
Wow... Yeah I know Samsung makes some decent things... but as for appliances... it would be my LAST choice... I know there are probably many people across the world perfectly happy with theirs...but for me.. no..
As for the tinted glass.... I think that would ANNOY me at first..you know, you get a new washer, you want to see how it works...then the newness wears off and you just want it to do its thing... Definitely some kind of bright light is needed to shine through the tint... BTW... Don't some models have interior lights that can be turned on during the cycle? I'm not sure... |
Post# 1182745 , Reply# 10   6/16/2023 at 08:09 (316 days old) by PinkPower4 (USA)   |   | |
Be careful. CLICK HERE TO GO TO PinkPower4's LINK |
Post# 1182755 , Reply# 11   6/16/2023 at 10:16 (316 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Yes, be careful. If you want to try to remove it, don't try to leaver it out, that will just lead to shattering. Cutting around it, through the glue, should work. As long as you have to use any force to seperate the 2 halves, you aren't done cutting. |
Post# 1182765 , Reply# 12   6/16/2023 at 12:24 (316 days old) by seedub (South Texas Hill Country)   |   | |
Post# 1182770 , Reply# 13   6/16/2023 at 14:02 (315 days old) by appnut (TX)   |   | |
Recently released new models from LG, WM6500 & WM5500 both inclue a rum light feature. And these are not the TOL models (next to TOL models). In LG's early ays, they had several moels that offered a drum light. But the last few years, this ne feature had been relegated to only their TOL model in a series. I think they were listening to many who were complaining in reviewss they wished there had been an interior light.
Post# 1182780 , Reply# 14   6/16/2023 at 18:11 (315 days old) by Spinspeed (Far North New South Wales Australia (originally London UK))   |   | |
I tried to remove the dark glass from my new LG washer and it did shatter in to thousands of bits. Was a bit of a disaster but then once all the shattered glass had gone I was left with a ring of dark glass stuck to the door and it looked horrible. I covered it with a plastic ring I got made to measure and it looks great. I love my new LG washer with the 4 water jets. It has some interesting drum movements too. Really glad I can see in clearly now.
Post# 1182781 , Reply# 15   6/16/2023 at 18:18 (315 days old) by Spinspeed (Far North New South Wales Australia (originally London UK))   |   | |
Post# 1182809 , Reply# 16   6/17/2023 at 08:29 (315 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I would not buy a front load washer that you could not see through easily. That would be one of the items that would be a dealbreaker when looking at a washer.
Unfortunately, especially here in the US there are not a lot of great 24 inch compact front load washers, While Samsung certainly has its problems LG isn’t really any better. We are not finding any of the 24 inch machines at hold up particularly well maybe Miele does better if you have a good local service and you should consider one of those. As for microwave ovens that catch fire internally this is a problem at all microwave ovens have occasionally especially the newer higher powered thousand watt models. This is not a particular problem with Samsung with only 61 complaints on file since 2011 that’s nothing. Do keep in mind if you have a microwave oven with a metal shelf in it, do not leave the metal shelf in the microwave oven unless you have two large plates of food in the microwave oven at the same time one plate on the shelf, and one plate on the turntable below. It’s not particularly hazardous it won’t spread because of the metal cavity. The real problem with over the range microwaves is putting it over a range when you have a range top fire, it tends to set the plastic door, control, panel, etc. on fire and then you have a real problem on your hands, not a good idea to ever put a microwave oven over a cooking surface. John |
Post# 1182821 , Reply# 18   6/17/2023 at 13:06 (314 days old) by ea56 (Cotati, Calif.)   |   | |
I can understand that having a dark colored glass window in the door of a FL washer would be bothersome. But wouldn’t you have known that the glass was smoke colored when you made your purchase?
And if you take the glass out, HOW are you gonna find a replacement in clear glass that is the exact match in size and shape to fit the door? Then install it so that it is water tight and doesen’t leak? Plus, making a DYI alteration like this in a brand new washer is likely to void your warranty. Just seems like a very ill advised thing to do.
It would be better to just not buy a washer with a smoke colored glass window in the door in the first place if this was going to be such an annnoyance.
Eddie |
Post# 1182842 , Reply# 19   6/17/2023 at 23:16 (314 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1182986 , Reply# 20   6/19/2023 at 20:18 (312 days old) by seedub (South Texas Hill Country)   |   | |
For me there were no other choices. (o:`,
I wanted a compact unit that I could roll around, hook up to the kitchen sink and store in a closet. The Equator filled the bill nicely. After using a Giantex semi automatic with spinner (an accident destroyed it requiring replacement), the prospect of a front loading combo allowing me to both wash and dry in the comfort of my own sub 500 square foot home was attractive. |
Post# 1183029 , Reply# 21   6/20/2023 at 11:34 (312 days old) by ea56 (Cotati, Calif.)   |   | |
Chris, I can certainly understand your space constraints, sorry that I wasn’t aware of this. I know that there are limited options for smaller washers that will fit in the space that you have to work with. I have limited space in my home too for the newer FL washers. And the smaller ones don’t meet my needs. Its frustrating when you can’t find the washer that meets all you needs.
I wish you the best of luck in being able to find a clear replacement window for your Equator washer door. And that you’ll be able to install the replacement so that it is water tight. Personally I would have left well enough alone, but whats done is done. I agree that smoke colored glass in an FL door is a bad idea.
Eddie |
Post# 1183147 , Reply# 22   6/21/2023 at 17:54 (310 days old) by seedub (South Texas Hill Country)   |   | |
