Thread Number: 93622
/ Tag: Vintage Dishwashers
Help! Looking for Kitchenaide Hobart KDS-18 timer |
Post# 1182886 , Reply# 1   6/18/2023 at 19:13 (320 days old) by qsd-dan (West)   |   | |
Getting tricky to find these timers in NOS condition but they occasionally pop up on Ebay. There's currently a rebuilt one for $75 if you want to take a chance on it.
https://www.ebay.com/itm/354098067406QUE... |
Post# 1182944 , Reply# 2   6/19/2023 at 12:28 (319 days old) by Cherokee (Southern CA)   |   | |
I took a chance on it. Not a hard decision because there are literally no other options! Really appreciate your help, qsd-dan. |
Post# 1182946 , Reply# 3   6/19/2023 at 13:14 (319 days old) by qsd-dan (West)   |   | |
Post# 1183089 , Reply# 4   6/20/2023 at 23:12 (318 days old) by Cherokee (Southern CA)   |   | |
Isn’t filling with water. I replaced the fill valve first but that didn’t fix the issue. The only dishwasher repair guy I could get to come out then said the timer was the issue. Hope he’s right. |
Post# 1183204 , Reply# 5   6/22/2023 at 15:57 (316 days old) by qsd-dan (West)   |   | |
Post# 1183205 , Reply# 6   6/22/2023 at 16:06 (316 days old) by Maytag85 (Sean A806)   |   | |
Post# 1183650 , Reply# 7   6/28/2023 at 15:27 (310 days old) by Cherokee (Southern CA)   |   | |
Well, replaced the broken timer with a rebuilt one purchased on eBay and everything is working great! Shout out to qsd-dan for the help. Much appreciated. |
Post# 1183651 , Reply# 8   6/28/2023 at 15:35 (310 days old) by qsd-dan (West)   |   | |
Post# 1183694 , Reply# 9   6/28/2023 at 20:46 (310 days old) by RP2813 (Sannazay)   |   | |
Post# 1183716 , Reply# 10   6/29/2023 at 00:32 (310 days old) by jil1000 (Northern CA )   |   | |
Post# 1183793 , Reply# 11   6/30/2023 at 04:19 (308 days old) by Cherokee (Southern CA)   |   | |
Good tip on the broken timer, sannazay. I did keep it. Gotta say, KDS-18 is working like champ again and I’m thrilled.
Post# 1183960 , Reply# 13   7/2/2023 at 00:21 (307 days old) by qsd-dan (West)   |   | |
Post# 1183965 , Reply# 14   7/2/2023 at 03:19 (307 days old) by biggpete (Hillsborugh County Florida)   |   | |
Yes, that is correct ’qsd-dan.’ As odd as it may sound, that’s what is happening. Thank you for the response and info. I did look this part up on eBay. It’s saying OEM Whirlpool. Will this fit my machine? |
Post# 1183966 , Reply# 15   7/2/2023 at 04:43 (306 days old) by qsd-dan (West)   |   | |
The valve will fit, I've used a couple of them on my Hobart dishwashers including a KDS-18.
The original valve is a dual inlet setup and the new valve is a single like all modern appliances use today but it functions the same. Just use electrical tape on the extra 2 wire connectors so they don't energize or short out on surrounding metal. |
Post# 1183970 , Reply# 16   7/2/2023 at 06:08 (306 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This is a fairly common problem and one of the many problems that can occur with an inlet valve.
If it’s a lightly used machine, you can take the valve apart and clean it and it will probably start working again. Portable KDS 58 Only had a single inlet valve as it was manufactured, KitchenAid didn’t worry about the portables flooding because the user could turn the water off so easily if it started to happen. They also were trying to save a few dollars. They also were trying to save a few dollars. The portable was already a very expensive machine. John |
