Thread Number: 93663
Maytag He front loader question. |
Post# 1183121   6/21/2023 at 11:28 (311 days old) by Laundryboy (Orlando Florida & Moravia NY. )   |   | |
Post# 1183131 , Reply# 1   6/21/2023 at 14:02 (311 days old) by lakewebsterkid (Dayton, Ohio)   |   | |
She may be using a product on that cycle that is too high sudsing. My old Duet would do it slightly. If there is a lot of detergent build-up, it will likely do it as well. She should try to use Citric Acid while running that cycle. |
Post# 1183146 , Reply# 2   6/21/2023 at 17:42 (311 days old) by DADoES (TX, U.S. of A.)   |   | |
Tide Washer Cleaner generates bunches of suds in my experience with it, and the instructions state to run it on the Normal cycle, not a designated Tub Clean cycle. Splashless and scented chlorine bleach products may also generate sudsing. Affresh does not, and Lemishine (which is citric acid) does not. Tub Clean cycles typically fill to a higher level and run the drum at distribution speed to slosh the water around more vigorously, which increases sudsing with products that cause it, and increased possibility of leaking from the tub vent. |
