Thread Number: 93668
Unfortunate news about the ‘63 Whirlpool |
Post# 1183170   6/22/2023 at 00:10 (317 days old) by Maytag85 (Sean A806)   |   | |
Hi folks, I have some unfortunate news about my ‘63 Whirlpool. The timer seems to no longer function as intended on the gentle cycle (haven’t got around to seeing what it would do on the wash n wear cycle). So here’s what happened, back in January the cam assembly separated in half (no idea how that happened), took the machine out of service and set it to the side. JB-Welded the cam assembly back together and used it a few times on the regular cycle and a few times on the super wash cycle, everything functioned as intended without issues. However, I decided to test it on the gentle cycle to be sure everything worked 100% before putting it back into service, it agitates and fills like it’s supposed to but here’s where the issues are: doesn’t spin on the gentle cycle and it spray rinses as though the valve is stuck open, timer advances to the rinse, fills up and does the same thing towards the end of the gentle cycle. Checked the spin solenoid and mercury capsule switch and those appear to be fine. Not sure how to go about fixing this issue with the timer (that’s why I created the thread about Midwest Timer Service) but all it appears to be is the cam assembly and nothing else. Kind of bummed about this, but I’m sure I’ll find a way to either have the timer rebuilt (up in the air at this point) or find a way to have a new cam assembly made (probably will be difficult to do) or see if anyone has a NOS 1963 Whirlpool Imperial Mark XII timer here in the forum.
Post# 1183203 , Reply# 1   6/22/2023 at 15:23 (316 days old) by Maytag85 (Sean A806)   |   | |
Post# 1183210 , Reply# 2   6/22/2023 at 16:44 (316 days old) by RyneR1988 (Indianapolis)   |   | |
Post# 1183212 , Reply# 3   6/22/2023 at 17:01 (316 days old) by Maytag85 (Sean A806)   |   | |
Same here, everything else on the timer appears to be fine, just the cam assembly that’s messed up. If there were a way to 3D print the cam assembly or have another one made, the machine would be back up and running again. Even contacted MTS to see if they would rebuild the timer and unfortunately they don’t rebuild timers anymore, kind of a foolish for their business plan since it means fewer customers for them.
Post# 1183233 , Reply# 4   6/23/2023 at 00:17 (316 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 1183260 , Reply# 5   6/23/2023 at 10:20 (315 days old) by Maytag85 (Sean A806)   |   | |
Here it is, the very front of the cam assembly separated from essentially the back half. JB-Welded it back together and I think it’s off kilter enough to cause it to not want functional properly on the gentle cycle.
Post# 1183300 , Reply# 6   6/23/2023 at 21:09 (315 days old) by bigalsf (Salt Lake City)   |   | |
Hi Sean, Call can you post a picture of your timer dial? I might have a timer that will work for you. |
Post# 1183304 , Reply# 7   6/23/2023 at 22:21 (315 days old) by Maytag85 (Sean A806)   |   | |
Here’s a picture of the timer dial. I think your 1963 Whirlpool Imperial has a similar but mine has everything built into the timer while the Imperial has separate temperature selections but otherwise has the same if not similar features to the Mark XII.
Post# 1183513 , Reply# 9   6/26/2023 at 22:59 (312 days old) by Maytag85 (Sean A806)   |   | |
Post# 1183516 , Reply# 10   6/26/2023 at 23:28 (312 days old) by bigalsf (Salt Lake City)   |   | |
Normal speed for the first 6 min & Gentle the last 4. Stays at Gentle speed for remainder of the cycle. |
Post# 1183517 , Reply# 11   6/26/2023 at 23:35 (312 days old) by Maytag85 (Sean A806)   |   | |
Post# 1183530 , Reply# 12   6/27/2023 at 07:12 (312 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Sean and Alan, unfortunately, the timer Alan has will not work on your washer without a lot of modifications it would be easier to fix the original timer.
In addition to not having the temperatures built into the timer, you have to be able to mount the stop lock plate to the front of the timer the shaft is different, John |
Post# 1183591 , Reply# 13   6/27/2023 at 21:50 (311 days old) by bigalsf (Salt Lake City)   |   | |
Thanks for clarifying John. I see your point about the built-in water temperatures. Sorry this didn't work for you Sean. Hope you're able to get it working again soon. It's a beautiful machine! |
Post# 1183593 , Reply# 14   6/27/2023 at 22:27 (311 days old) by Maytag85 (Sean A806)   |   | |
Thanks Al. Definitely a favorite out of all the machines I own, hopefully I can find a replacement or possibly find some way to 3D print the cam assembly since that’s all that is really wrong with it. Rebuilt the transmission 2 years ago back in May of 2021, it’s been in and out of service but has probably done at least 700+ loads of laundry since I rebuilt the transmission. May be a bit much to use a machine that’s almost 60 years old as a daily driver but really are only 45 years old since they were used from 1963 to 2005 and 3 years since I’ve owned them since 2020. If Midwest Timer Service still rebuilt timers, I’d practically would have a machine that’s been rebuilt but since MTS doesn’t rebuild timers (kind of foolish from a business perspective since it means one less customer for them), kind of bummed but I guess that’s how life goes at times.
This is what the gears looked like in the transmission when I rebuilt it 2 years ago, hardly if any wear at all. |
Post# 1184231 , Reply# 15   7/5/2023 at 16:02 (303 days old) by Maytag85 (Sean A806)   |   | |
Post# 1184255 , Reply# 16   7/6/2023 at 00:14 (303 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
Hi Sean,
I consulted my old 1992 whirlpool parts catalog, which has all the timers that had been used in their automatic washers from the 1950s to 1992, and that part number you listed is not coming up either as an original or as a replacement part. Can you verify either the original timer part number or the part number of what is in the machine now? The original timer is probably a five digit part number. I am hoping that we can find some more recent sub numbers that might be in stock somewhere on eBay, etc. Gordon |
Post# 1184264 , Reply# 17   7/6/2023 at 08:12 (303 days old) by Maytag85 (Sean A806)   |   | |
Hi Gordon,
The part number I came up with was from a friend Mikey Randall who used to be a repair tech for Sears many years ago, messaged him about the timer since he mentioned about MTS (Midwest Timer Service) but quickly found out that they no longer rebuild timers. After some searching around, that’s the part number he came up with 364996. There are numbers 793-004-1, 84147, NM508-109-2, March 1963. Not sure if those mean anything but those are the only other numbers I can find on the timer itself. |
Post# 1184273 , Reply# 18   7/6/2023 at 09:55 (302 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
That number 84147. Looks like the part number for the timer but you need the original cross reference book. I have one somewhere I don’t have time to look for it this morning but that number probably crosses over to the timer you need.
There’s a good chance I have a timer for that machine, but again it takes quite an effort to look for it. I’m looking for someone to come and help organize all the whirlpool Kenmore parts. There are just boxes and boxes of them. John |
Post# 1184274 , Reply# 19   7/6/2023 at 10:00 (302 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1184395 , Reply# 20   7/8/2023 at 00:43 (301 days old) by Maytag85 (Sean A806)   |   | |
Post# 1184493 , Reply# 21   7/9/2023 at 05:02 (300 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Sean, the timers in the 63 and 64 whirlpool imperial mark 12s may be very similar. I would be willing to bet they probably aren’t the same but in any case I don’t think the timer for the 64 is real common either
You certainly can use your washer without the gentle cycle I wouldn’t imagine that you almost ever use a gentle cycle anyway. You should also be able to fix the cam block with the proxy and then take a Dremel and grind it as necessary to make it work again, certainly a tedious process, but I’ve seen it done. John. |
Post# 1184547 , Reply# 22   7/9/2023 at 18:46 (299 days old) by Maytag85 (Sean A806)   |   | |
Hi John, I may look into making further repairs to the cam assembly but here’s something else I may try. I’ll ask my younger sister in Arizona if her boyfriend knows of anyone who has a 3D printer along with scanning the cam assembly and using CAD to make some adjustments to the cam assembly since it’s ever so slightly crooked which may be why it’s not working properly on the gentle cycle.
I could just use the regular cycle, but just want to have everything in working order so I won’t have to go back and do everything all over again. |
