Thread Number: 93702
/ Tag: Wanted to Buy Items
~1960 tappan microwave handle and drawer |
Post# 1183489   6/26/2023 at 18:02 (307 days old) by classiccaprice (Hampton, Virginia)   |   | |
After years of hunting I finally found a early Tappan microwave. This one was built in January 1960. It's a water cooled unit , which is interesting. Supposedly it worked when it was removed, but this was told to me by the seller had it listed as a wall oven. Unfortunately, the contractors that removed it threw away the recipe drawer and broke the handle.
I highly doubt anyone has the drawer, so I figured I'll try to make a cover for the hole. However I figured it wouldn't hurt to see if someone has a drawer lying around. Also, would anyone happen to have a parts Tappan wall oven from about the same year that I could get a handle off of? It's made of pot metal, so it would be a challenging repair. Thanks everyone.
This post was last edited 06/26/2023 at 21:17 |
Post# 1183503 , Reply# 1   6/26/2023 at 20:22 (307 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi, Will, don’t try to power up that oven without making sure there’s an antifreeze solution in the cooling system and that the pump and everything is turning and pumping, etc. before powering it up.
The handle should be a relatively easy fix. It would be neat if it actually worked, I have yet to get one of these early microwaves to work. Let everybody know how it goes. John |
Post# 1183508 , Reply# 2   6/26/2023 at 21:19 (306 days old) by classiccaprice (Hampton, Virginia)   |   | |
Post# 1183587 , Reply# 4   6/27/2023 at 21:08 (305 days old) by classiccaprice (Hampton, Virginia)   |   | |
Post# 1183616 , Reply# 5   6/28/2023 at 08:14 (305 days old) by cspetros (Portsmouth, VA)   |   | |
Sent you an email! |
