Thread Number: 93789
here we go again again 2 |
Post# 1184365   7/7/2023 at 18:50 (301 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
having to deal with the Maytag dryer
Now the calypso washer have a problem the control console LED and time indicator have problems lighting up I thought the ribbon cable was loose and needed to be seated BUT The socket on the control board is loose Need advice on how to proceed Should replace that one board Both boards or the whole console entirely wo9rks fine otherwise except the bleach hose leaks once in a while due to the seal being bad |
Post# 1184494 , Reply# 1   7/9/2023 at 05:06 (300 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
If the socket on the board is loose, you can send it to course centric‘s and have it re-soldered.
I don’t understand why you would replace both boards the whole consul etc. do you have all these parts laying around? If you have the parts go ahead and replace everything, none of those three parts are still available but you can find good used ones if you want to look around for them Where the bleach hose attaches to the outer tub they had trouble with leaks. It’s very easy to take it apart clean everything up and use a very good sealant. When you lock it back into the tub, I would use 3M, marine sealant , John |
Post# 1184554 , Reply# 2   7/9/2023 at 19:53 (299 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
thanks John
tinkering with the Maytag in the background But and it is a big but I have a bigger problem than this The Calypso is totally dead I want to check it so i can use it and I pressed the buttons on the console but it will not start at all None of the buttons will turn it on So I gotta figure out what happened |
Post# 1184558 , Reply# 3   7/9/2023 at 20:26 (299 days old) by luxflairguy (Wilmington NC)   |   | |
This should and could be in ONE thread! Please don't start another about the same shit different day! |
Post# 1184635 , Reply# 4   7/10/2023 at 19:40 (298 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1184903 , Reply# 5   7/14/2023 at 19:43 (294 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1185187 , Reply# 6   7/18/2023 at 13:01 (291 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1185204 , Reply# 7   7/18/2023 at 17:43 (290 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
As it’s always unusual seeing Calipsos |
Post# 1185692 , Reply# 8   7/23/2023 at 21:32 (285 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1185697 , Reply# 9   7/23/2023 at 22:13 (285 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1185913 , Reply# 10   7/26/2023 at 15:06 (282 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1187164 , Reply# 11   8/8/2023 at 22:22 (269 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1188189 , Reply# 12   8/22/2023 at 14:19 (256 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1190568 , Reply# 13   9/24/2023 at 15:47 (222 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1191410 , Reply# 14   10/6/2023 at 19:51 (210 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1192226 , Reply# 15   10/19/2023 at 18:02 (197 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
here is is
Need to know if this is acceptable need to figure out why it is narrow CLICK HERE TO GO TO bpetersxx's LINK |
Post# 1192234 , Reply# 16   10/19/2023 at 21:54 (197 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1192421 , Reply# 17   10/22/2023 at 23:29 (194 days old) by rodknock95 (Salem, Missouri)   |   | |
I have never seen one of those. Wow |
Post# 1192433 , Reply# 18   10/23/2023 at 10:14 (194 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1192534 , Reply# 19   10/25/2023 at 11:08 (192 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1192536 , Reply# 20   10/25/2023 at 12:45 (192 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1192537 , Reply# 21   10/25/2023 at 12:48 (192 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1192538 , Reply# 22   10/25/2023 at 12:50 (192 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1192580 , Reply# 23   10/26/2023 at 13:48 (191 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
the machine controller board is bad
In the troubleshooting book Page 56 Motor and Motor Control System Test Machine control relay 4.Set the probes of a volt-ohmmeter between P16-5 (BK/WH) and P16-1 (WH/BU) on the ma- chine controller. Start the washer by pressing HEAVY DUTY and then START. Confirm that 120VAC is present when the relay clicks closed. Press STOP/CANCEL twice to stop the cycle. test 4 fails press Heavy duty but no start no relay click no beeps when button is pressed |
Post# 1192581 , Reply# 24   10/26/2023 at 14:28 (191 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1192583 , Reply# 25   10/26/2023 at 15:02 (190 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1192627 , Reply# 26   10/27/2023 at 13:16 (190 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1192660 , Reply# 27   10/28/2023 at 09:40 (189 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1192666 , Reply# 28   10/28/2023 at 13:21 (189 days old) by luxflairguy (Wilmington NC)   |   | |
Haven't a clue what 7 trigfyul.ft means! |
Post# 1193200 , Reply# 29   11/8/2023 at 05:24 by bpetersxx (laf in on the banks of the Wabash River)   |   | |
