Thread Number: 93798
/ Tag: Wringer Washers
My first Wringer washer |
Post# 1184460 , Reply# 1   7/8/2023 at 20:36 (300 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1184461 , Reply# 2   7/8/2023 at 20:43 (300 days old) by vacuumlad1650 (Grundy County, IL)   |   | |
How do you tell the date on these? |
Post# 1184462 , Reply# 3   7/8/2023 at 21:13 (300 days old) by Maytag85 (Sean A806)   |   | |
Post# 1184473 , Reply# 4   7/8/2023 at 23:05 (300 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1184481 , Reply# 5   7/9/2023 at 00:28 (300 days old) by qsd-dan (West)   |   | |
That wringer washer looks like it has been through the wringer.
These are pretty stout, clean up easily (fairly easy to repaint also), and can be rebuilt with plenty of available parts.
Since the motor is out, oil it if it has oil ports (the original motors from this time period had them) using Zoomspout turbine oil.
It would also be a good idea to install a 3 prong grounded cord. Lastly, replace the A4298 seal so water doesn't enter the transmission.
Post# 1184506 , Reply# 7   7/9/2023 at 08:56 (299 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Maytag wringer washers never had an "on/off" switch. Moment cord is plugged motor begins and will continue to run long as receives electricity. Round knob in front merely operates gears by "push/pull". When pulled out gears are shifted to allow agitation. Pushed in stops agitator from moving.
Wringer gears are controlled by lever on top of power mangle. Three positions: forward, neutral (no movement) and reverse. Maytag wringers obviously predate grounding requirements. However it sounds like your washer as a motor that has a ground, thus best to use a three pronged grounded power cord. Owner/installation manual for Maytag wringers do state while not preferred way of connecting use of a two prong cord to three prong electric adapter could be used. Since your motor is already away from washer with cord off I'd just go with wiring things properly and be done. OP you can find owner, installation and service manuals for Maytag wringer washers in "Library" section of Automatic washer available for download. Some makers of wringer washers did offer models with a timer that shut off agitation after certain period of time. Others just rang a bell after time elapsed but did not shut off anything. Maytag did offer one model with latter timer IIRC, but they are rare to find. Various companies made after market timers good for any semi-automatic washer. They looked not unlike the "on/off" programable timers used to turn on lights or other appliances. You plugged washer into "timer", plugged timer into wall, set things up and let timer take care of turning washer off and perhaps on. Obviously a timer that stops agitator was far more useful to most, pity Maytag never went that far. |
Post# 1184509 , Reply# 8   7/9/2023 at 09:02 (299 days old) by vacuumlad1650 (Grundy County, IL)   |   | |
I am assuming the eye terminal would be ground then. It looks like there is in fact a ground terminal behind it on the motor. |
Post# 1184618 , Reply# 9   7/10/2023 at 13:44 (298 days old) by hobbyapocalypse (Northeast Pennsylvania)   |   | |
