Thread Number: 93803
Help With Miele W1918 Drain Pump |
Post# 1185083 , Reply# 1   7/17/2023 at 06:29 (292 days old) by wardmatt (atlanta)   |   | |
EDIT: I took out the pump and tested resistance. It comes in a 7 ohms. Videos I have watched suggest it should be much higher, but I don't know if 7 counts as broken. Ideas please? TIA |
Post# 1185143 , Reply# 2   7/17/2023 at 20:28 (291 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 1185205 , Reply# 4   7/18/2023 at 18:06 (290 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Miele largely sources pumps for various appliances from Hanning. IIRC for W1918 would be Hanning EW, T-Nr 4251 170 (120V, 60Hz)
Then you have this: appliantology.org/topic/62750-mi... From above link apparently even low a 4 ohms may be considered normal. Miele used American "clothes dryer" connection for W19XX series washers, that is 120v/240v even though barely nothing in washer besides heating elements requires 240v. Pump is 120v but IIRC does need a neutral connection, something pure 208v-240v usually wouldn't. If connectors are smashed due to damage caused by tub movements failing to be controlled by (worn) dampers, then OP needs to sort out shocks as well. See also: www.automaticwasher.org/c... Very long story short is Miele no longer stocks new parts for W19xx washers from Germany. Whatever stock left in USA warehouses is all they've got and pumps are NLA. Plan "B" is to find NOS or even used parts from other sources such as online. Just take care of voltage and frequency. Early on Miele sourced pumps, timers and other bits for washers, dryers, dishwashers, etc... with 120v/60hz for things sold in North America. Thus same part for something sold in Europe or elsewhere may be of no use as will be 208v-240v/50hz. Depending upon part and function frequency may not be an issue, but voltage most certainly will. |
Post# 1185248 , Reply# 7   7/19/2023 at 10:45 (289 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
