Thread Number: 93830
/ Tag: Vintage Dishwashers
My KDS-18 has sprung a leak. Help! |
Post# 1184842   7/13/2023 at 19:25 (295 days old) by marky_mark (From Liverpool. Now living in Palm Springs and Dublin)   |   | |
Hi guys
My KDS-18 has never given me any problems until today. I started the machine and the tub filled normally but all the water leaked out over the course of around 5 minutes. The bottom of the motor is full of water and it appears that water has been sprayed all over the place by the motor.
The machine had been sitting in my unoccupied house for a month -- hot and dry with the A/C off. I thought the seals may have dried out and would re-seal themselves but so far it's still leaking like a sieve.
All thoughts appreciated! Mark |
Post# 1184845 , Reply# 1   7/13/2023 at 20:28 (295 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Mark, hopefully that should be an easy repair things like this to fail.
Seals do not dry out and fail, but it could have gotten stuck from sitting and just torn itself apart when it went to run, not a bad repair take the pump apart, carefully replace the drain impeller and seal. Hopefully you’ll be good to go. John |
Post# 1184849 , Reply# 2   7/13/2023 at 21:16 (295 days old) by marky_mark (From Liverpool. Now living in Palm Springs and Dublin)   |   | |
Thank you, John. Is this eBay item what I need to buy? I don't know if it comes with the plastic gauge that I believe is required to ensure correct spacing.
Thanks, Mark
Post# 1189307 , Reply# 3   9/4/2023 at 17:43 (242 days old) by marky_mark (From Liverpool. Now living in Palm Springs and Dublin)   |   | |
Thank you, John. I've now replaced the seal and drain impeller and it's working great again with no leaks. This machine really is built like a tank!
Mark
