Thread Number: 93839
Roper washing machine? |
Post# 1184909 , Reply# 1   7/14/2023 at 22:31 (294 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1184937 , Reply# 2   7/15/2023 at 10:09 (293 days old) by RyneR1988 (Indianapolis)   |   | |
The subject of used washer recommendations is getting tricky because so many appliances these days are not designed to be repaired. rather, they are manufactured in a way that they get sent to scrap as soon as something really major breaks on them. So, the used market isn't as prevalent as it once was unfortunately. I believe that Speed Queen is the main exception to this plastic-fantastic rule, but someone more knowledgeable than me can certainly chime in if I am off base in any way.
I do believe that the Whirlpool-built direct drive platform (the Roper above belongs to this group) is still a good choice for a used washer, but be aware that the newest of these is now around 13 years of age and will need at least some minor going over. I learned my lesson about that last year when I bought a direct drive Whirlpool washer from a used appliance dealer here in town. The machine was made in 2005 and I thought that since it came from a storefront type of situation it would be completely in working order, and the thing is, it mostly was but there were minor issues with it that became major difficulties over a few months. I wound up having several components replaced on it and the machine runs very well now, but my point is just to expect to do some work or hire someone to have it done if you buy one of these machines. It's very likely it won't be ready to jump into service as is if you want any longevity out of it. I hope this is helpful to you and I wish you and your sister luck. Ryne |
Post# 1184940 , Reply# 4   7/15/2023 at 10:28 (293 days old) by RyneR1988 (Indianapolis)   |   | |
Is she opposed to buying new? If not, there are a few options that would probably fit what she's looking for but be aware these are kind of bottomf-of-the-barrel models these days and won't last very long.
The model below is a decent option but it's now only available from Lowes. I used to have it, gearbox failed in just under six years but that is about how long things last now. This machine is all knobs with only one push-to-start button, as well as a deep-water option and traditional dual-action agitator. It does have a computer board controlling the cycles but they all do now. The completely analog timer controls are no longer available on washers at all as far as I am aware. Even Speed Queen, which held out the longest as far as that situation goes, now uses computer boards to control even their basic dial machines. Ryne www.lowes.com/pd/Whirlpoo... |
Post# 1184941 , Reply# 5   7/15/2023 at 10:33 (293 days old) by weed30 (St. Louis, MO)   |   | |
Your comments are great and something to think about. She might end up with a basic new model - I just hate that as you mentioned, the new appliances don't last very long. |
Post# 1184946 , Reply# 6   7/15/2023 at 12:41 (293 days old) by Good-Shepherd (New Jersey)   |   | |
Speed Queens www.facebook.com/marketpl... |
Post# 1184958 , Reply# 7   7/15/2023 at 14:18 (293 days old) by weed30 (St. Louis, MO)   |   | |
It turns out that I think I can fix her current washer :) Between here and youtube, it's likely the fill valve which is easy to replace, and the for the smell I'm getting some citric acid. I love this forum!! |
Post# 1184964 , Reply# 8   7/15/2023 at 15:02 (293 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
since 2021 i own this maytag topload washer www.maytag.ca/en_ca/washe... since 2021 and pretty satisfied with it
Post# 1184967 , Reply# 9   7/15/2023 at 15:28 (293 days old) by Good-Shepherd (New Jersey)   |   | |
Try bleach and hot water wash first. The smell is likely mildew and other crud probably from cold water washes, not enough detergent or bleach. Citric acid is good for hard water deposits |
Post# 1184972 , Reply# 10   7/15/2023 at 17:44 (293 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1184978 , Reply# 12   7/15/2023 at 18:40 (293 days old) by RyneR1988 (Indianapolis)   |   | |
Post# 1184979 , Reply# 13   7/15/2023 at 18:59 (293 days old) by weed30 (St. Louis, MO)   |   | |
My first post was wrong - definitely a Maytag. But the tag numbers indicate 2010 according to the site I used. |
Post# 1184980 , Reply# 14   7/15/2023 at 19:12 (293 days old) by qsd-dan (West)   |   | |
The helical design ceased production in 2006 so it's older than that.
Remove the front cover and see where the leak is coming from. It could just be as simple as a leaky hose clamp that needs tightening.
If the washer stinks, she's not using properly. Most likely way too many cold water washes. Do not let her purchase a front loader if she can't keep a top loader clean and aroma free. |
Post# 1184983 , Reply# 15   7/15/2023 at 19:25 (293 days old) by weed30 (St. Louis, MO)   |   | |
The leak is a drip coming from the little horizontal piece at the top of the tub that fills the washer - drip circled in photo. It drips about every 10 seconds.
Post# 1184985 , Reply# 16   7/15/2023 at 19:28 (293 days old) by qsd-dan (West)   |   | |
Post# 1184986 , Reply# 17   7/15/2023 at 19:30 (293 days old) by weed30 (St. Louis, MO)   |   | |
Post# 1184987 , Reply# 18   7/15/2023 at 19:33 (293 days old) by qsd-dan (West)   |   | |
Post# 1184988 , Reply# 19   7/15/2023 at 19:35 (293 days old) by weed30 (St. Louis, MO)   |   | |
Wow! So is WP22001274 the correct valve? |
Post# 1184989 , Reply# 20   7/15/2023 at 19:44 (293 days old) by qsd-dan (West)   |   | |
Yeah, that's the updated valve but I wouldn't trust it. It may be some Chinese junk that Whirlpool sources.
This is the older part# that's a direct fit. It's an NOS genuine Maytag valve for much cheaper than Whirlcharge wants.
https://www.ebay.com/itm/374807561061QUE...
Post# 1184990 , Reply# 21   7/15/2023 at 20:06 (293 days old) by weed30 (St. Louis, MO)   |   | |
are a gem!! Thank you!!!! |
Post# 1184991 , Reply# 22   7/15/2023 at 20:12 (293 days old) by qsd-dan (West)   |   | |
Post# 1185012 , Reply# 23   7/16/2023 at 08:36 (292 days old) by lovestowash (St. Petersburg, FL)   |   | |
Post# 1185015 , Reply# 24   7/16/2023 at 09:44 (292 days old) by DADoES (TX, U.S. of A.)   |   | |
weed30: "The model she has is LAT5005AAW, serial number A0107023, manufactured in March 2010 according to the decoder I found." qsd-dan: "If that's KB to the far right, it was built in January, 1994....pushing 30 years of age." Weed30, the KB characters are set away from the rest of the serial number (per your photo of the tag) but they are a relevant part (code for the year/month of factory production) of Maytag's serial syntax used at the time. |
Post# 1185034 , Reply# 27   7/16/2023 at 15:59 (292 days old) by RyneR1988 (Indianapolis)   |   | |
George, that really stinks and I would have been highly upset. It indeed sounds like you got a lemon from the factory. Yeah, after being on this forum for some time as well as stories I've heard from others, I expect my VMW washer lasted about as long as they're expected to. What a shame, but it is what it is.
Like you, I now have an older direct drive washer, but mine is Whirlpool rather than Kenmore and a few years newer than yours I believe. I am much happier with it than I was with the VMW, although as I pointed out earlier in this thread, the entry level VMW washers are a decent machine for someone who finds themselves in a pinch and just needs a washer cheaply and quickly. They'll definitely get the job done, but they're not the best quality by any stretch. I'll be buying a front loader when my direct drive begins to have too many problems, as I don't think any top loader built today is worth much. Ryne |
Post# 1185039 , Reply# 29   7/16/2023 at 17:23 (292 days old) by Good-Shepherd (New Jersey)   |   | |
The washer in that vid is a different design than your sister's LAT series Maytag. "Norge Tag" I believe they're called. |
Post# 1185041 , Reply# 30   7/16/2023 at 17:44 (292 days old) by weed30 (St. Louis, MO)   |   | |
Thank you again! |
Post# 1185099 , Reply# 31   7/17/2023 at 10:15 (291 days old) by lovestowash (St. Petersburg, FL)   |   | |
Ryne, indeed it could be described as a lemon, and I started to send it back. However, with the ordeal of taking time off from work, and scheduling service calls, I opted to have this one repaired, rather than take a chance of another lemon. I failed to mention, I had to have a 2nd service call shortly thereafter, as the earlier technician failed to reassemble the tub correctly in place. Since I began working in the appliance department at Home Depot, I have found that it's not uncommon to deliver a washer that's DOA.
George |
