Thread Number: 93859
Speed Queen Spins Getting Weired |
Post# 1185080   7/17/2023 at 04:08 (286 days old) by chetlaham (United States)   |   | |
At first I was upset/surprised by the default low speed first spins in each cycle. Now it seems like Speed Queen 15 seconds into the first spin pauses, starts the motor for 1/2 a second, pauses for 5 more seconds than goes back to low speed.
Huh? Why? Is this intended? I'm confused.
Starting at 18:28 and 1:00:30 >>>
This post was last edited 07/17/2023 at 08:39 |
Post# 1185081 , Reply# 1   7/17/2023 at 05:11 (286 days old) by qsd-dan (West)   |   | |
Post# 1185082 , Reply# 2   7/17/2023 at 05:30 (286 days old) by chetlaham (United States)   |   | |
Post# 1185089 , Reply# 3   7/17/2023 at 08:02 (286 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I think you mean Speed Queen. What's with the low speed spin on heavy duty? I like fast speed spin both after main wash and final deep rinse. |
Post# 1185093 , Reply# 4   7/17/2023 at 08:40 (286 days old) by chetlaham (United States)   |   | |
Post# 1185119 , Reply# 5   7/17/2023 at 13:20 (285 days old) by Egress (Oregon)   |   | |
The display flashes oFlo when the motor shuts off, so maybe it momentarily tripped the overflow switch? not sure. |
Post# 1185139 , Reply# 7   7/17/2023 at 19:44 (285 days old) by chetlaham (United States)   |   | |
Ok, yes, I see that now! Wow! I never knew these even sensed an overflow condition.
What would cause this? Could the flood pressure switch simple be set to low? Or is the machine actually spinning to fast?
I'd think, IMO, that even with a slow drain pump the tub should still drag indefinitely at a speed that doesn't cause water to overflow out of the top. |
Post# 1185148 , Reply# 9   7/17/2023 at 21:15 (285 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1185160 , Reply# 10   7/18/2023 at 00:21 (285 days old) by washdaddy (Baltimore)   |   | |
the machine is flashing that oFlo msg in the first and second spins the third time the machine drains the msg once again pops up but the machine doesn't stop like it does on the first two |
Post# 1185177 , Reply# 12   7/18/2023 at 10:29 (285 days old) by WindRivers (Wind River Range, WY)   |   | |
Sorry, actually I believe the spray starts 1 minute after the spin starts. But still, the water is completely drained well before then. |
Post# 1185179 , Reply# 13   7/18/2023 at 10:50 (285 days old) by WindRivers (Wind River Range, WY)   |   | |
Chetlaham, does your old Speed Queen washer drain that slow, even on slow spin? |
Post# 1185223 , Reply# 14   7/18/2023 at 21:20 (284 days old) by chetlaham (United States)   |   | |
I would say my Speed Queen drains a bit slower than this machine when on low speed, if not equal. And yes, my AWN412SP sprays with the tub still 1/3 full of water on Permanent Press and Delicate with the water level on medium or large.
However, what I notice is the tub spins and accelerates faster during spin-drain where as my machine spins slower during drain, also water doesn't slosh up and down the tub cover like in the video.
I'm now waging a bet the belt isn't slipping enough.
But I sure do like seeing that enhanced swirl-away drain |
Post# 1185229 , Reply# 15   7/19/2023 at 00:24 (284 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I am not impressed with the slow spin after the main wash at even on heavy duty. I had a feeling that the motor would cut out in the back of my mind. What were they thinking? Why did they do that? |
Post# 1185231 , Reply# 16   7/19/2023 at 01:13 (284 days old) by chetlaham (United States)   |   | |
The motor should not cut out on a low speed spin-drain. The slip in the belt is supposed to prevent the motor from being overloaded with to much torque. It is physically impossible to spin a tub full of water at 640rpm with a practically sized motor so some type of clutch must be used, be it a shoe/drum or a variably tensioned belt.
However, thats not to say I disagree with you Jerome. I'd absolutely loose my marbles if my Queen spun low speed in the normal cycle.
I think Speed Queen needs to listen to those posting on this forum. |
Post# 1185244 , Reply# 17   7/19/2023 at 09:43 (284 days old) by DADoES (TX, U.S. of A.)   |   | |
My guess is that either the wrong belt is on the machine or it's too tight (if there's an adjustment), causing excessive current draw on the motor in a way that's specific to low-speed spin acceleration, if that's a possibility. The belt on this haul-away machine was bad and replaced before running it, per the video's description. |
Post# 1185319 , Reply# 18   7/20/2023 at 01:51 (283 days old) by chetlaham (United States)   |   | |
