Thread Number: 93898
GE Agitator |
Post# 1185634   7/23/2023 at 10:35 (286 days old) by cycla-fabric (New Jersey (Northern))   |   | |
Can someone tell me why this agitator in this GE washer is one of the worst I have seen in washing a load of clothes. This thing has no ability to turn over a load of clothes at all. All it does is swish them back and forth, rollover is a joke. The machine is claimed to be a V16 which isn't true, as the service book claims that the tub will hold either the V12, V14, or v16 agitator in it. Well this straight vane agitator is one I want to change out, does anyone have the curved vane agitator that they want to sell that maybe a replacement for this one. The model number of this machine is wa1040 e a from 1969 as told from my previous post on this washer find. Thanks
Doug |
Post# 1185636 , Reply# 1   7/23/2023 at 11:03 (286 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1185678 , Reply# 2   7/23/2023 at 19:08 (285 days old) by cycla-fabric (New Jersey (Northern))   |   | |
Post# 1185685 , Reply# 3   7/23/2023 at 20:13 (285 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
I had a GE with the same agitator in a tub not bigger than a pail, must have been an 8 pounder.. It didnt work worth crap on turnover, agitation was too fast and beat everything then I bought my Maytags in 1984 which still work perfectly. Let the GE go with a tenant and far as I know it is still working.
Post# 1185750 , Reply# 5   7/24/2023 at 11:19 (285 days old) by bradfordwhite (central U.S.)   |   | |
Changing the agitator in this water hog isn't going to change the stroke span.
If you don't love this machine, replace it with something with a triple action agitator at least. Maybe a Whirlpool made direct drive model.
Post# 1185753 , Reply# 6   7/24/2023 at 13:07 (285 days old) by bajaespuma (Connecticut)   |   | |
This GE Activator known as the "Straight-6" was designed primarily for a larger Mini-Basket with less consideration for the machine as a conventional washer (although I wonder if they didn't switch to this straight-vaned agitator to help them claim a larger capacity from less water displacement). You don't have to be a hydrodynamics engineer to notice that the 6 vanes on the bottom of this agitator are small and short while the 3 vertical vanes are large which isn't particularly helpful if you want a lot of rollover. The original Bakelite version of the Straight-6 was black and had small vanes at the bottom which were slightly longer and protruded outside the circumference of the Activator base (which might have helped a little).
It'll still do the job but only if you don't overload the washbasket at all. The Spiral Activators did a much better job at muscle-ing large loads down, up and around.
You can replace this Activator with any Spiral version from the V-12's up to and including the "HEAVY DUTY 16's ( you just need to make sure that the internal spline is compatible with your Activator post) |
Post# 1185924 , Reply# 8   7/26/2023 at 20:56 (282 days old) by Laundryboy (Orlando Florida & Moravia NY. )   |   | |
