Thread Number: 93961
/ Tag: Modern Dryers
Speed Queen Dryer Drama |
Post# 1186282 , Reply# 1   7/30/2023 at 15:53 (272 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1186524 , Reply# 3   8/1/2023 at 18:23 (270 days old) by ea56 (Cotati, Calif.)   |   | |
Get a BOL Maytag or Whirlpool dryer. My Maytag dryer is over 7 years old and has never has a single problem or repair. Even the light bulb in the drum still works. They are good basic and sturdy dryers.
The link I’ve attached is the current equivalent of the dryer that I have.
HTH Eddie https://www.lowes.com/pd/Maytag/5013606511
Post# 1186541 , Reply# 4   8/1/2023 at 19:15 (270 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1186546 , Reply# 5   8/1/2023 at 19:36 (270 days old) by qsd-dan (West)   |   | |
Post# 1186553 , Reply# 6   8/1/2023 at 21:07 (270 days old) by chetlaham (United States)   |   | |
Post# 1186773 , Reply# 7   8/3/2023 at 21:35 (268 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Just replace the heating element. It’s a 15 minute do it yourself job it only requires the removal of four screws.
All 240 V electric dryers occasionally have bad heating elements. It’s usually related to higher than average voltage at your house or a long vent run. As mentioned by others, it’s unlikely that the timer is also bad, you’re probably higher voltage or long vent probably caused the other repair you had already with this dryer. Many dryers have problems like this. Speed Queen is actually one of the better ones in this regard. John |
Post# 1186797 , Reply# 8   8/4/2023 at 05:38 (268 days old) by Frigilux (The Minnesota Prairie)   |   | |
My sister and I have 2017 Series 9 electric Speed Queen dryers. Mine needed a new relay board—heat would not shut off at all during the cycle—but it was still under warranty, so no cost to me. Unfortunately, my sister is on her third heating element. She lives in a condo building with a fairly long duct run, but the late ‘80s Whirlpool dryer that preceded it never had a problem with that. Special shout-out to John L. (combo52) for diagnosing both problems correctly!
Post# 1186806 , Reply# 9   8/4/2023 at 09:59 (267 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Speed Queen makes a special lower wattage element for the situation’s and this element should be installed if it’s a long vent run or higher than average voltage.
This is a problem with almost all US electric dryers when the voltage is high or the vent runs or long GE used to have special elements for this problem but they no longer sell them. Whirlpool does not sell them and we have a huge problem with whirlpool and Kenmore dryers burning out elements and safeties under these conditions. I often substitute the element on standard 29 inch whirl pools with the one from the little compact 240 V dryer and on the 27 inch dryers we use the one from the stack 27” dryer because it has lower wattage and that illuminates the problem of repeat failures. John |
Post# 1187318 , Reply# 11   8/11/2023 at 03:01 (261 days old) by mark_wpduet (Lexington KY)   |   | |
What is considered a "long vent run"
I think, if I were to guess, mine is possibly 15 to 20 feet..starting in the laundry room and going straight up, then a slight turn then straight up to the roof.. all rigid metal.. but I have a special setup that keeps my vent run entirely clean and clothes dry fast.. I have a 4 year old whirlpool standard dryer with no issues.. I always thought most dryer issues with either people not cleaning the lint screen or long "clogged" vent runs, not long "clear" vent runs. TBH.. I've always been jealous of people who were lucky enough to have a dryer vent straight out on an outside wall. |
Post# 1187358 , Reply# 12   8/11/2023 at 18:15 (260 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Bobby , do you have any idea what the voltage is in your house at the dryer outlet? If it’s over 240 V I would consider putting the lower wattage heating element in.
The inlet heat grill gets stuff burned on it if there’s not enough airflow, or if the heater is running excessively hot, you can easily take that grill off heat it up and take a wire brush and brush the burned accumulation off of it. It’s not actually the grill falling apart. I have cleaned many of those when I am reconditioning a heavily used. Speed queen dryer for resale. John. |
Post# 1187467 , Reply# 13   8/13/2023 at 01:20 (259 days old) by bradfordwhite (central U.S.)   |   | |
One needs to know the entire route and condition of the dryers vent system. If any part of it is restricted, damaged, crushed, or packed with lint; it won't matter what dryer you connect to it. No dryer will work correctly.
One house I owned in 2002 had a first floor laundry that had a 30'long run to the back of the house. It was clogged with lint and when I investigated where it terminated it was under a deck AND whoever built the deck made no provisions for the vent plus they put a board over half the hole. Not good. |
Post# 1187477 , Reply# 14   8/13/2023 at 09:59 (258 days old) by mark_wpduet (Lexington KY)   |   | |
My friend Joanne... who lives on the other side of town in an older, but nice typical neighborhood on a cul-de-cac... I was at her house one day visiting and we were talking about her new machine that she had just bought... I was asking her about dry times and if she ever cleaned her vent run? She said clothes dry fast and no issues but she had never cleaned it or even thought about it...We were outside her house and trying to figure out where the vent exited and we absolutely couldn't find it anywhere.... not even the roof...Her laundry was in the middle of the house and connected to a back wall...We were like, "Maybe it goes in the attic? She's been in her attic and sees no sign of lint anywhere..she looked all over the place up there... so it's a total mystery
Post# 1187485 , Reply# 15   8/13/2023 at 11:37 (258 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
Vents into the void? Or would it vent into an old chimney like some hot water heaters |
Post# 1187488 , Reply# 16   8/13/2023 at 12:06 (258 days old) by DADoES (TX, U.S. of A.)   |   | |
"She said clothes dry fast ..." Depends on what's her reference for fast. "She's been in her attic and sees no sign of lint anywhere..she looked all over the place up there.." She probably didn't recognize what is the ducting. My guess is it goes through the attic and exits on the roof. My neighbor has his machines in middle of the house, with a 4" PVC in the slab, exiting I believe at the edge (which occasionally results in it filling with water during a heavy rain). A friend lives in a log cabin on a slab, also has a PVC in the interior wall, down through the slab and up in the yard similar to this photo. I recently repaired his dryer (bad belt) which had sat unused for a few years(!). He was using his dad's dryer. Upon finishing the repair and testing the machine, there was a lot of backflow from the exhaust. I went outside to locate the exit and there was zero airflow. He wasn't home, I left an advisory note detailing the problems that would result from the obstruction. Called him later, he said he cleared the clog.
Post# 1187505 , Reply# 17   8/13/2023 at 14:07 (258 days old) by bradfordwhite (central U.S.)   |   | |
If she has a crawlspace, the duct may just go down thru the floor and end. There is vents all the moisture and lint into that space. I've seen that lots of times. #16 OMG PVC! I've never seen that but I've seen the manufacturers installation books that strongly forbid it AND venting into an old chimney. Piping underground, probably without double walling it...... dumb. The average person just doesn't understand pipes and wires behind the walls. They just don't seem to put it together in their minds....which is kind of sad. As a result it can lead to some really tragic and sometimes funny things.
Post# 1187530 , Reply# 18   8/13/2023 at 19:59 (258 days old) by mark_wpduet (Lexington KY)   |   | |
it's definitely not the roof...because there was no specific roof cap that was for a dryer.. It's not that big of a home. I think it's a concrete slab foundation. It has to go somewhere....I know a lot of people wouldn't know what to look for but I described what to look for...and months later after having that conversation with her...she had someone over doing something to her house and she told me on the phone that she mentioned that to the guy that was there doing work and he was up there in the attic and he couldn't find it either...She was baffled and on a mission to find it but she never did...she gave up.
Post# 1187554 , Reply# 20   8/14/2023 at 07:12 (258 days old) by bobbyderegis (Boston)   |   | |
John, I have no idea what the voltage is coming out of the wall or how to test it. What a nice little pair this is, despite the grate issue. Bobby in Boston
Post# 1187555 , Reply# 21   8/14/2023 at 07:44 (257 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1187701 , Reply# 22   8/16/2023 at 01:21 (256 days old) by DADoES (TX, U.S. of A.)   |   | |
