Thread Number: 93998
Need Help Picking a New FL Set |
Post# 1186702 , Reply# 2   8/3/2023 at 12:35 (268 days old) by panasonicvac (Northern Utah)   |   | |
Post# 1186706 , Reply# 3   8/3/2023 at 12:57 (268 days old) by Logixx (Germany)   |   | |
Have seen videos of the recent GEs and what I saw was very lackluster. No recirculation, no spray rinse, if there are spins between the rinses (there hardly seem to be) they are slow, while the final spin is very long. Others have shown mold growing in the Microban door seal.
The LGs seem to do everything the GEs don't. I guess achieving water temperatures between warm and extra hot is difficult with any of the US washers. The Electrolux washers are very nice as well. For me, a firm believer in thorough rinsing, the use of the extra rinse button would be obligatory for the same reasons that apply to the GE (short or lacking spins during the cycle). http://youtube.com/@washertester4296 |
Post# 1186709 , Reply# 4   8/3/2023 at 13:06 (268 days old) by kb0nes (Burnsville, MN)   |   | |
Replacing that functioning SpeedQueen front loader with anything else would be an epic mistake. It will likely outlast several of anything else.
I don't recall what happened to the dryer, but it certainly can be fixed, although their dryers aren't necessarily the best of the best. Some of it comes down to if you must have matching appliances. I'm soundly a form follows function person so it doesn't matter to me. I just can't see hemorrhaging money for something that doesn't matter (to me). |
Post# 1186710 , Reply# 5   8/3/2023 at 13:16 (268 days old) by ea56 (Cotati, Calif.)   |   | |
The OP’s washing machine isn’t a SQ FL, its a SQ TL AWN432.
I would agree with you though that just replacing the dryer would be smartest. But I can understand that some may prefer to have a matching set, especially of their machines are in an area, other than a dedicated laundry closet that makes them visible.
Eddie |
Post# 1186731 , Reply# 6   8/3/2023 at 14:58 (268 days old) by mark_wpduet (Lexington KY)   |   | |
I have to say that LG with turbo wash...but I agree the Elux looks good (but for some reason they don't put a coin trap (kind of important).. And from what I've seen, the LG's are the easiest to work on should a repair be needed in the future.
As for temps... there may be fiddling...but at least it IS possible with some fiddling. I'm really surprised they don't get as good of ratings as the Lux because the wash/rinse action looks so much better.. |
Post# 1186845 , Reply# 8   8/4/2023 at 19:48 (267 days old) by nmassman44 (Brooksville Florida)   |   | |
Before you go ahead and think about fiddling with the water levels in the new washer…see if it meets your needs first. I have an LG WM4000 that uses plenty of water and the TurboWash feature works quite well. You will find that the water levels in the wash cycle will be lower but that is to concentrate the detergent solution. Rinsing is superb since each spin uses a spray rinse and followed by a deep rinse. The water level will come to the bottom of the door boot and you can add up 3 extra rinses of if you like. The washer should have AI built into it as well. It will only work with Normal and Bright Whites cycles. At least in my machine that is how it is set up. Also connecting it to the internet will allow LG to diagnose an issue and also do software updates if needed. You will love this choice of washer. The dryer is superb and is very quick. Drying is spot on with the Normal cycle. It uses AI and adjusts the heat as the load dries much like Whirlpool’s Gentle /Soft heat so loads don’t over dry. I use that cycle for everything. LG’s are very well made in my opinion and they are reliable.
Post# 1186866 , Reply# 9   8/5/2023 at 00:00 (267 days old) by appnut (TX)   |   | |
Post# 1186873 , Reply# 10   8/5/2023 at 04:56 (266 days old) by mark_wpduet (Lexington KY)   |   | |
Hey appnut. Glad you're still liking your LG... the moment my duet dies that's the one I'm getting.... I'm not sure which model...but definitely one with turbo wash.
Poster: I'm glad you're getting the LG....Hope you like it.. Getting a new washer in 2023 is so hard because everything is so sketchy! I've seen videos of modern washers in action on youtube and a lot of them I would only want to have if I was totally desperate. I did come across a video of a recent whirlpool FL washer video...I was a little impressed with the recirculation... It was almost like a fan spray...but I swear it used so little water in wash/rinse/rinse (same levels on all of them)..You would think they would give at least a little more water in the rinses...but not at all from what I could tell. Perhaps it was the cycle chosen and it could possibly be different on other cycles... I don't know.. Also, the whirlpool/maytag with wash plates just don't seem to have as good of wash action as the samsung/LG/GE with wash plates...at least from the videos I've seen...and some of the HE top loaders that have an agitator looked awful..but then a few of them looked pretty good. For example: I saw two GE washers with an agitator. One of them, the agitator looked like one piece, while the other looked two piece.. similar to the dual action agitator.. |
Post# 1186882 , Reply# 11   8/5/2023 at 08:32 (266 days old) by powerfin64 (Yakima, Washington)   |   | |
Post# 1186897 , Reply# 12   8/5/2023 at 11:34 (266 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
The GE "ultrafresh" seems like a scam. As Logixx stated above, he's seen mold growing on the seal. Don't fall for that scam. This post was last edited 08/05/2023 at 16:21 |
Post# 1186932 , Reply# 13   8/5/2023 at 19:51 (266 days old) by mark_wpduet (Lexington KY)   |   | |
True... but if washer manufacturer designs something into the machine to inhibit mold/smells... It wouldn't stop me from buying it whether that part worked or not, because I would continue to do what I've always done.. Most people on here don't have mold issues...It's so freaking easy to keep that from happening..the only thing I would see being and issue "possibly" is if the washer is not in a climate controlled area... a house that doesn't have AC in a humid area..
Post# 1186974 , Reply# 14   8/6/2023 at 10:46 (265 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
In terms of performance, reliability and easy to repair is easily a speed, queen pair.
Next best would be something from Maytag or whirlpool. These are also union built in the United States. I will not buy Chinese built machines notice LG Samsung and GE all have a high percentage of Chinese components, some of them are outright built and assembled there. John |
Post# 1186977 , Reply# 15   8/6/2023 at 12:29 (265 days old) by nmassman44 (Brooksville Florida)   |   | |
Well LG and Samsung machines are designed in Korea and my LG washer was built here in the USA in TN. Many of the components are made here as well. Whirlpool/Maytag also have components made in China but if you look at the relabilty that LG has ...Whirlpool cant even come close. Now Speed Queens are way overpriced for what one gets ...no water heater in the washer and the dryer lacks in so many ways for the price. Everyone has their opinions about certain brands and this is mine.
Post# 1186979 , Reply# 16   8/6/2023 at 13:48 (265 days old) by powerfin64 (Yakima, Washington)   |   | |
Post# 1186984 , Reply# 17   8/6/2023 at 14:27 (265 days old) by appnut (TX)   |   | |
Post# 1186986 , Reply# 18   8/6/2023 at 14:46 (265 days old) by panasonicvac (Northern Utah)   |   | |
Ours is the WM8100HVA along with the matching DLEX8100V electric dryer. We've been really pleased with them. Best laundry set we've ever had in our house.
Post# 1187009 , Reply# 20   8/6/2023 at 21:19 (265 days old) by mark_wpduet (Lexington KY)   |   | |
I think I trust WP refrigerators the most...and dryers
but their FL washers when they started using plastic instead of glass in the window turned me way off from their washers. I don't like that their TL HE washers with wash plate don't seem to have as good of wash action as the other TL HE washers I've seen (not that I would buy any of them) It's really hard to escape CHINA products in anything Lorainne(S?) Furniture did a full breakdown of the LG washers to see how easy a repair would be and he totally recommended them compared to others. This was five years ago (the video) but I think it still mostly applies to their washers today. CLICK HERE TO GO TO mark_wpduet's LINK |
Post# 1187033 , Reply# 21   8/7/2023 at 08:08 (264 days old) by IIIJohnnyMacIII (North Carolina)   |   | |
I believe from threads that I’ve read that LGs do get up to proper temps: 140 for hot, 105 for warm, ect. All you have to do is select the corresponding temp with the highest soil setting, I believe. You can even check your washer’s temps with the press of a couple buttons. There is a great thread on it somewhere in here that explains it well.
Post# 1187036 , Reply# 22   8/7/2023 at 09:35 (264 days old) by appnut (TX)   |   | |
John, great minds thn alike. I was gettng ready to address this subject. The temps you cite were before the latest round of energy star adustments in like 2016 or 2017.
Push the delay wash and temp buttons to see what Temp (in celcius) is. The following temps are for Whites, Perm Press, Bulky/Bedding, and Towels. Hot is 112, warm is 90. For these cycles the heater does come on but once the set temp is reached, it turns off an does not come back on to maintain. These temps are also the same for Heavy Duty, but the heater never comes on for those temps. For Normal hot is 95 an warm is 80. Extra Hot on Normal & Heavy Duty is pure hot water fill and depending upon soil level, wlll heat water from 140 to 160. If you add 4 to 6 cups of water to the tub before puttng in laundry, that wll trick the machine into thinking it's a very heavy load. That results in more water being added per fill, each rinse segment is doubled (1 minute is 2, 2 is 4, ...) and the final spin is lengthened. Extra high on Normal And Heavy Duty add about 18-20 minutes to final spin but doesn't get a spin speeed of more than 1120-1160, not the 1300 rpm. Seen a couple of comments in YT videos confirming this. Have only seen ex high spin speed get to 1190 to 1210 once. This post was last edited 08/07/2023 at 10:17 |
Post# 1187055 , Reply# 23   8/7/2023 at 15:03 (264 days old) by panasonicvac (Northern Utah)   |   | |
I like using the towels cycle for towels, warm temperature for colored and hot for whites with bleach. I use delicates for stuff that can't go into the dryer. Speed wash for something I'd clean really fast with. And normal for everything else, warm temperature for colored and hot for whites, some whites I'd use bleach but some I don't. Only the towels I can get up to two extra rinse cycles while the others I can use up to three. And the delicates can't use the turbo wash jets while the other cycles can. I don't use the extra hot or steam temperature anymore as I find they don't make much of a difference from my experience. Bleach with hot water is what helps clean and maintains the washer tub from any build up, just make sure you leave the door open whenever someone isn't using it. If you're using powder detergent or fabric softener, be careful not to use too much as that can build up inside the dispenser tray compartment. Honestly, I don't use fabric softener. I'd rather use vinegar instead which can also help clean and maintain the tub. And I clean the lint trap out about once a month.
As for the dryer, I use the towels cycle for all the towels. Delicates for silk quilts. And normal for everything else with the wrinkle care mode on. Once in a while I'd use the steam cycle to unwrinkle some things, it works but it doesn't fully replace an iron or a hand steamer. If clothes or towels aren't completely dry, I'd use the timed cycle to finish up as it doesn't use the moisture sensor. Make sure all the lint is out of the trap before you'd start the next cycle which I'm sure you already know that. I vacuum out the inside of the lint trap about once a month with this attachment. And be careful not to open up the lint trap door completely as the plastic will break, mine broke from opening it too widely. www.amazon.com/Cleaner-Va... |
Post# 1187062 , Reply# 24   8/7/2023 at 16:50 (264 days old) by decodriveboy (FL, US)   |   | |
Thanks for the tips! Which cycles have the highest water level for wash and rinse from your experience? |
Post# 1187073 , Reply# 25   8/7/2023 at 17:58 (264 days old) by panasonicvac (Northern Utah)   |   | |
Post# 1187105 , Reply# 26   8/7/2023 at 23:04 (264 days old) by mark_wpduet (Lexington KY)   |   | |
Last night I got lost for 4 hours scrolling through youtube shorts...I just kept watching one, and scrolling down...watching another, scrolling down and I couldn't stop!!
I came across several videos that a couple of appliance techs out in the field doing repairs or cleaning stinky machines...They must really run across this MORE OFTEN than not...I just can't believe there are so many people out there who don't know how to do laundry and how many disgusting machines they come across...The techs seem to think people should stop using Fab Softener and don't use too much detergent...Like that's the CAUSE of their issues when it's so much more than that... I think these people are packing their machines full and using way too much product and most likely using tap cold... a recipe for disaster as has been discussed on here a lot.. One tech was not a fan of anything but SQ....He basically bashes all other brands and I get where he's coming from. SQ's are built like a tank..but I've watched MANY LG videos and I think lots of people are very happy with them...sure, things can go wrong.. I still think people should plug their washer into a surge protector even though it's built in. |
Post# 1187113 , Reply# 27   8/8/2023 at 07:07 (263 days old) by mark_wpduet (Lexington KY)   |   | |
I mean, one look at this and you can't see that whoever owned it just didn't care...and he's blaming the fab softener... does he seriously think that if you just took the fab softener out of the equation this machine would probably magically look perfect?
Post# 1187137 , Reply# 28   8/8/2023 at 13:44 (263 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Thanks for all your research Mark do you have more patience than I do to watch four hours of videos of washing machines of course I work on washing machines all week long.
Reply 27 is barely worth a few seconds. It takes to watch it but it shows how little most repair people know about washing machines. Yes, fabric softener can contribute to nasty build ups in washing machines, but the real problem is not washing in hot enough water using enough good detergent, etc. If you use fabric softener, you must wash it out thoroughly both out of the machine and the clothing the next time you wash, so it really requires hot water and plenty of good detergent. Speed Queen, washers and dryers are in a class by themselves they are the only machines you can buy that are based on machines that are intended for commercial use. It’s much like KitchenAid dishwashers of old. They were the same basic machine that was used in commercial establishments. John |
Post# 1187154 , Reply# 29   8/8/2023 at 17:39 (263 days old) by littlegreeny (Milwaukee, WI)   |   | |
Post# 1187156 , Reply# 30   8/8/2023 at 17:54 (263 days old) by johnb300m (Chicago)   |   | |
Post# 1187159 , Reply# 31   8/8/2023 at 19:00 (263 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi David, Speed Queen has always had a plastic door strike on the door since their first front load washers almost all companies use plastic for this part I have never seen one break. It’s a really tough material. Here are pictures of my 18 year old Speed Queen frontload washer in my current three-year old one they use the same latch.
All door locks on all machines worldwide are plastic as well. You’re far more likely to have a door lock part of the machine fail. There are many parts on machines today that failed door locks on almost all washing machines are a problem area as our drain pumps and water inlet valves and there isn’t much difference whether are talking about a Frigidaire or a Miele or Speed Queen. John This post was last edited 08/08/2023 at 20:01 |
Post# 1187167 , Reply# 32   8/8/2023 at 22:53 (263 days old) by mark_wpduet (Lexington KY)   |   | |
I wouldn't say I spend a whole lot of time watching that...The other night when I was watching youtube shorts it was all sorts of different types of videos.(not just laundry)..and I found almost all of them interesting. I think it's because the videos are so short like Tiktok
I do wonder what changes LG makes in their FL washers with turbo wash from year to year... their latest one with AI looks like a nice machine, but I haven't actually seen it wash... It has turbo wash but I wonder if it's equivalent to one from a couple of years ago vs now. My fear is by the time I need one they will have dumbed everything down each year until I no longer like them... |
Post# 1187174 , Reply# 33   8/9/2023 at 02:43 (263 days old) by Logixx (Germany)   |   | |
Post# 1187175 , Reply# 34   8/9/2023 at 05:07 (262 days old) by mark_wpduet (Lexington KY)   |   | |
Thanks Logixx
Wow - whatever is going on after the first spin here is really cool.. It reminds me of what my duet does only this is even more extreme than mine...Like it spins after first wash then fills with water but the drum slowly keeps spinning pushing rinse water through everything...I haven't seen any of the other turbo wash cycles I've seen do this. I think whoever this is chose the normal cycle (shocking).. It looks REALLY good. I already like it CLICK HERE TO GO TO mark_wpduet's LINK |
Post# 1187177 , Reply# 35   8/9/2023 at 08:55 (262 days old) by RyneR1988 (Indianapolis)   |   | |
Mark, what you are discussing is a major reason why I was contemplating buying a new washer even though my current machine works fine. I don't want to be in a situation where I wait for my washer to break down and then there's literally nothing I like out there to choose from. It could be that in a few years even FL's will have been hit with dumbed-down cycles so hard that most everything just kinda sucks. I hope that doesn't happen of course, but time will tell. But yes, I'd like a new washer at some point while the current offerings are available, because who knows what's coming next in the lineup of energy savor washers? And I'm not even against energy saving or government regulations, but I just wonder how far they can go before washers just aren't very effective.
Ryne |
Post# 1187178 , Reply# 36   8/9/2023 at 09:23 (262 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It’s very unlikely that anything is going to change much with the design and water use a front loading washers in the next five or 10 years.
They may get a little more expensive or they may even stay stable or come down in price some. I certainly don’t see any reason to buy anything now if you don’t need it. There have been so many changes in the last decade is really a good time to wait and let things settle out a little bit so that reliability and so forth can be better predicted. John |
Post# 1187179 , Reply# 37   8/9/2023 at 09:26 (262 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Or recirculated water, wow this looks exciting to watch and does get the detergent and everything mixed up and wet faster there is no proven benefit in cleaning and in fact, it picks up all the dirty, sediment and lint from the sump and just throws it back on your clean laundry constantly.
It also adds to the energy consumption of the machine and it’s one more thing to break down make noise, etc. John |
Post# 1187182 , Reply# 38   8/9/2023 at 09:40 (262 days old) by petek (Ontari ari ari O )   |   | |
I was just reading through this and saw that John just posted what I was thinking. When it comes to all these cycles on front loaders in particular there is a point of diminishing or no returns at all and the rest is just smoke and mirrors. For instance I have the LG WM3700 and my clothes come out perfectly clean on the regular or heavy duty cycle. Heck even a few things tossed in on Speed Wash 15 minutes come out clean. I can guarantee you that if I had the fancier model with "turbo wash" the clothes would come out no cleaner than my machine without that feature.
Post# 1187190 , Reply# 39   8/9/2023 at 12:15 (262 days old) by mark_wpduet (Lexington KY)   |   | |
About the waiting for the washer vs getting one now for fear they may all suck in the future... I doubt that will happen. Why do I say that? Because I've had this fear for years and years now and that fear never comes to pass. Each year there is something on the market that I would want....Granted, I don't feel like there are huge options..but there are always a few.
You're probably right about the turbo wash vs non-turbo wash... but why not go for turbo wash when you can get one for around $799? I remember when it first came out the turbo wash was a few hundred more |
Post# 1187201 , Reply# 40   8/9/2023 at 15:10 (262 days old) by Logixx (Germany)   |   | |
That "distribution" rinse only seems to occur on the Normal cycle. Don't know how or if this changes if extra rinses are selected. It would be better if the jets were on to spray rinse water over the clothes. Without the jets, it looks like the rinse doubles as a tub clean cycle.
Skip to 21:20 in the video. CLICK HERE TO GO TO Logixx's LINK |
Post# 1187210 , Reply# 41   8/9/2023 at 18:03 (262 days old) by appnut (TX)   |   | |
Post# 1187212 , Reply# 42   8/9/2023 at 18:17 (262 days old) by RyneR1988 (Indianapolis)   |   | |
Thanks for the peace of mind John, as I've stated before I spent quite a bit of money early this year getting the DD repaired that came to me in poor shape. If I can keep it for a few years and just get something when it actually breaks that would obviously be preferable.
After all the DD is an old mechanical timer-style machine that I can opperate perfectly independently without modification why fix something that's not broken? Honestly I'd like to get away from a top loader eventualy but right now that's what I have so it's totally fine. Ryne |
Post# 1187251 , Reply# 43   8/10/2023 at 06:21 (261 days old) by mark_wpduet (Lexington KY)   |   | |
So I noticed watching this guys videos with the square door LG a couple of things and I wonder....how are the two square models different from each other? And how are the other round door turbo wash models different from those? Also, I noticed that when rinsing, not only was turbo wash spraying constantly...but also the spray nozzle at the top was filling.. It looked like a water party...so is the machine filled from 2 places? The bottom and the spray nozzle?
Post# 1187256 , Reply# 44   8/10/2023 at 09:01 (261 days old) by powerfin64 (Yakima, Washington)   |   | |
Mark, the answers are:
1) they are different capacities- one is bigger than the other, different cycles/options. 2) If the model is labeled with "turbo wash" its 2 recirculating jets, if the model is labeled with "turbo wash 360" then its 4 recirculating jets. 3) Yes, it is, but mainly through the dispenser drawer |
Post# 1187698 , Reply# 45   8/16/2023 at 00:10 (256 days old) by panasonicvac (Northern Utah)   |   | |
Actually with the Turbo Wash jets, I have noticed a difference with mine. Not only I find they do a better job washing but also they help reduce the time during a cycle. So energy saving wise, I don't think it matters really. While I do agree that it's just an extra thing that can go wrong on a washer, I think it's rare for it to ever break according to my research. But you don't have to use it if you don't want to. And I agree with Mark, why not get a LG with Turbo Wash jets for way less versus a SQ that doesn't even have that feature for the price they're asking?
Post# 1187713 , Reply# 46   8/16/2023 at 09:35 (255 days old) by RyneR1988 (Indianapolis)   |   | |
What I'm not a fan of is that turbo wash models, from what I can tell, all come with other extras that I don't think I would want like steam and WiFi. The pricing structure of LG's lineup kind of stinks because you have the entry level machines, with very few add-ons, then you climb up the price tier and get several features such as turbo wash, steam, and WiFi. But i'm willing to bet turbo wash is the main extra folks care about, so I wish it was offered on their cheaper entry models and customers could ditch the other extras. You get the whole package whether you wantit or not and have to pay for it.
Post# 1187714 , Reply# 47   8/16/2023 at 09:38 (255 days old) by RyneR1988 (Indianapolis)   |   | |
I guess all of LG's machines have WiFi per se, in that they all have smart diagnosis but they don't all have full app connectivity. I imagine a lot of people don't care about full app connectivity but buy the model that has it, along with steam, just so they can have the turbo wash. I think that's a crappy pricing structure.
Post# 1187737 , Reply# 49   8/16/2023 at 15:24 (255 days old) by panasonicvac (Northern Utah)   |   | |
Post# 1187916 , Reply# 51   8/18/2023 at 13:18 (253 days old) by panasonicvac (Northern Utah)   |   | |
Post# 1187918 , Reply# 52   8/18/2023 at 14:05 (253 days old) by mark_wpduet (Lexington KY)   |   | |
Skimpy water levels...I don't feel like reading through this forum again... but I have a question... is this your first FL washer? or was your previous a FL?
I remember back in 2005 when I got my duet I was so freaked out about the water levels..I think it's a shock to someone who is sued to a TL washer... The videos I've seen with your LG in operations with different cycles... it looks like it uses as much if not more water than my duet from 2005 |
Post# 1187921 , Reply# 54   8/18/2023 at 15:02 (253 days old) by appnut (TX)   |   | |
Post# 1187923 , Reply# 55   8/18/2023 at 15:19 (253 days old) by decodriveboy (FL, US)   |   | |
I agree! Very disappointing that Speed Wash doesn’t have at least a brief spin between the wash and rinse. As such, this necessitates an extra rinse :/ |
Post# 1187924 , Reply# 56   8/18/2023 at 15:22 (253 days old) by appnut (TX)   |   | |
Post# 1187928 , Reply# 57   8/18/2023 at 16:57 (253 days old) by mark_wpduet (Lexington KY)   |   | |
I'm very confused but I'm seeing adequate water in the cycles I've seen so far...Granted, I agree with you as I would always like a little more... but I think yours is every so slightly too much. For me, I'd want it to just touch the bottom of the boot... No more than that. These LG's must be way easier to adjust the water than on my 2005 Duet....because YEARS ago I tried this and it was a total fail...Here's what would happen when I tried that:
Turn screw a little at a time until you like the water level you're at... which is what I did...but there was never a noticeable change...so I would keep turning a little, then a little more...until it went from one extreme to the other...water literally filling 1/2 up the freaking window... so I turned the screw back down to where it was and never messed with it again. Keep in mind that when I did all this, I did it exactly as was described online at the time for my machine...and each time you tried it... you had to make sure to drain complete, unplug, and start over... |
Post# 1187937 , Reply# 59   8/18/2023 at 18:44 (253 days old) by mark_wpduet (Lexington KY)   |   | |
so just so I'm clear... even before any adjustments... the LG uses more water for rinses than it does for washes? It sounds like that's what you were describing above...
Yep - definitely too much soap in that one in the picture...You wanna know what's weird? Over the years of having my Duet, I have never seen the first soap bubble in it when doing laundry...the only time I've seen actual bubbles is when I'm washing something small.. I guess it's my hard water. I don't know. |
Post# 1187975 , Reply# 61   8/19/2023 at 15:30 (252 days old) by mark_wpduet (Lexington KY)   |   | |
Based on videos I've seen of this washer (before any adjustments) I think I'd be happy with the water because of the recirculation...Low water wash doesn't bother me.. low water rinse really bothers me..but it's really good to know you can make adjustments...but there's a fine line where the baffles won't work well with too much water and the clothes just roll around instead of lifting and dropping...and honestly, it doesn't take much more water before that actually starts happening..I'm thinking for me, 1/2 turn would be enough..
Post# 1187984 , Reply# 62   8/19/2023 at 19:13 (252 days old) by nmassman44 (Brooksville Florida)   |   | |
One has to remember that with the LG washer the wash drum is tilted so the back of the washer has plenty of water for the clothes. I have noticed that with the Normal cycle the wash water levels are less than the rinse levels and it also bases the water levels based on load size sensed if that makes sense. Also AI is used in the Normal and Bright Whites cycles and it changes cycle parameters based on soil level, load size and what it senses that the load is. I use Bright Whites for , well , Whites and Towels. I find that the Towels cycle is painfully long while Bright Whites will cut an hour or so off the total time and yet still give me a 10 minute final spin time and the towels emerge damp dry. Heavy Duty cycle will use more water and it will default to Heavy soil levels. The Allergiene Cycle uses very hot water and the heater is on and it uses plenty of water.
I would have thought twice before fiddling with the water levels since if you ever need service , you might have voided the warranty for the washer. I am 2 years in with my WM 4000 and DLEX4000 dryer and have no issues with either one. They have performed very well and in fact CU rated this pair the #1 choice according to the website. |
