Thread Number: 94100
/ Tag: Modern Dryers
Do the newest Speed Queen DR7's still burn clothes? |
Post# 1187992 , Reply# 1   8/19/2023 at 20:29 (251 days old) by DADoES (TX, U.S. of A.)   |   | |
D510701 = 225-40F D515873 = 205-40F D510324P = 5.0KW (5000 watts) D510329P = 5.35KW (5350 watts) I find the above specs via searching sources for the items. The revised high-limit thermostat is 20°F lower trigger temp. The revised element is 350 watts more heating capacity. ETA: The high-limit thermostat monitors the element* and shouldn't trigger unless airflow is restricted/obstructed. *Or gas burner, although gas models may take a different P/N with a different trigger temp. |
