Thread Number: 94187
/ Tag: Modern Dishwashers
KDTM604KPS |
Post# 1188809 , Reply# 1   8/29/2023 at 10:49 (242 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
You should try the prowash cycle with prodry and hightemp wash on. |
Post# 1188819 , Reply# 3   8/29/2023 at 15:09 (242 days old) by luxflairguy (Wilmington NC)   |   | |
This is a dishwasher? Who made it? The title line doesn't say... |
Post# 1188820 , Reply# 4   8/29/2023 at 15:18 (242 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I suspect it was built by Whirlpool. |
Post# 1188821 , Reply# 5   8/29/2023 at 15:19 (242 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
What rinse aid do you use? I use Cascade Power Dry which works very well. |
Post# 1188823 , Reply# 6   8/29/2023 at 15:31 (242 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1188834 , Reply# 7   8/29/2023 at 17:33 (241 days old) by lakewebsterkid (Dayton, Ohio)   |   | |
Yes, it's a KitchenAid. |
Post# 1188835 , Reply# 8   8/29/2023 at 17:34 (241 days old) by lakewebsterkid (Dayton, Ohio)   |   | |
Finish Jet Dry Ultra from Costco |
Post# 1188851 , Reply# 9   8/29/2023 at 23:05 (241 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
What detergent do you use? I use Cascade complete in mine and I've yet to have any issues. |
Post# 1188872 , Reply# 12   8/30/2023 at 09:33 (241 days old) by appnut (TX)   |   | |
Post# 1189032 , Reply# 13   8/31/2023 at 23:52 (239 days old) by Egress (Oregon)   |   | |
I don't believe I have heard a whining noise from the 3rd rack, but the dishwasher occasionally makes a "fart" sound which I believe is the diverter valve moving. we use cascade powder. |
Post# 1189072 , Reply# 14   9/1/2023 at 12:43 (239 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I've had sudsing issues with Finish products before. I like Cascade for the cleaning power and smell. The suds level varies in my Kenmore equivalent to Bosch. I'm currently using Cascade Complete in the citrus breeze which doesn't suds. |
Post# 1189179 , Reply# 15   9/2/2023 at 16:39 (237 days old) by johnb300m (Chicago)   |   | |
Whirlpool-made dishwashers, all the way back to the pressure sensor KUDS25 will activate the “medium soil” level of the cycle program if “Hi Temp” is selected. So you got two pre-rinses because of that.
ProWash will almost always do 1 prewash, also. Normal, to save water, will go right to MainWash with no options and soil is light enough. Even with moderate soils. Normal has a pretty high threshold to kick up to a medium or high soil sense program change. |
Post# 1189191 , Reply# 16   9/2/2023 at 19:50 (237 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
The normal cycle on my Kenmore would do the same thing. I'm quite certain that if I select turbo clean, it would add another prerinse. |
Post# 1189725 , Reply# 19   9/10/2023 at 00:15 (230 days old) by appnut (TX)   |   | |
It occurred to me this evening a wish--when KitchenAid brings out new models or design, I want the higher end models to hhave inline heating rather than the heating element at the bottom. The top two models for GE Profile & Cafe lines have inline heating. The last dishwasher Frigilux bought from GE before he sold his house had inline heating. He really liked it. I think the KA design should devise a way to heat circulated air with the inline heater for indirect drying.
Post# 1189746 , Reply# 20   9/10/2023 at 12:54 (230 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It doesn’t make any difference whether the elements in the bottom of the tank or built into the pump assembly.
And when it’s built into the pump assembly, it’s very costly and difficult to replace it also often causes pump damage because the pump housing is plastic and it has a heating element in it when something goes wrong. KitchenAid, along with every other major dishwasher sold in the US has had plenty of problems in the last decade. I’m glad they have not done this one additional troublesom some thing. Not having the heating element in the bottom, eliminates the possibility of having a really effective drying system to that can get the job done more quickly. John |
Post# 1190148 , Reply# 24   9/17/2023 at 14:25 (223 days old) by appnut (TX)   |   | |
