Thread Number: 94277
another hotpoint Empress |
Post# 1189696   9/9/2023 at 15:10 (237 days old) by anthony (uk)   |   | |
Post# 1189805 , Reply# 1   9/11/2023 at 13:21 (235 days old) by anthony (uk)   |   | |
on this today .the pump was stuck solid so i thought i would do that first .once i got it off the machine and dismantled i found it wasnt in too bad a state .A strip down clean and plenty of lubrication put that right .the wiring is in a bad state and there seems to be oil seeping from the gearbox into the motor [anyone know how the motor comes off?] The stop/start switch is broken [black button missing]so i'm trying to work out how to fit a modern push button switch into the old housing . The chances of getting a replacement are rather slim but if anyone has one im interested. A few pictures to be going on with .More to follow
Post# 1189857 , Reply# 2   9/12/2023 at 13:45 (234 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Hello Anthony
Great you have bagged another Empress from the marvelous restoration you did on your early model , this should be easier . Nowthen, you ,ay luck about the Hotpoint switches , but I cant get to them for a week or so to check , I got a stash of parts from Sam Watson rescued from an old repair shop closing down in East London, well we opened them up and lots of spares we thought we`d never need and there you go, I get it to you as soon as can , they are over at Als in the garage but hes up to his eyes in it at the mo...
Post# 1189868 , Reply# 3   9/12/2023 at 17:16 (234 days old) by anthony (uk)   |   | |
Post# 1189990 , Reply# 4   9/14/2023 at 15:02 (232 days old) by anthony (uk)   |   | |
today .first i did the wringer .the grease in the gearbox was so stiff i needed two hands to switch it on . got rid of all the old grease and then washed everything with white spirit .Slapped some new grease in and its all working smoothly . next i gave it a rub down ready for paint .While that was drying i started to remove the tub and gearbox .Its taken all afternoon but finally its out ready for a good clean and lube . Its not possible to remove the motor while its in one piece so i removed the field coils exposing three bolts holding the motor housing to the gearbox .I have not disturbed them because there is no sign of any oil getting in that way so once everything is cleaned i will put it back together .I have opened the gearbox just to see what state the oil is in and i have to say its looking good so i am just going to top it up so for those of you who have always wondered what's in the gearbox on an empress hears your chance to find out
Post# 1189991 , Reply# 5   9/14/2023 at 16:04 (232 days old) by Slowspin66 (lincoln uk)   |   | |
Post# 1190045 , Reply# 6   9/15/2023 at 15:35 (231 days old) by anthony (uk)   |   | |
filled the gearbox up with oil and put the lid back on then cleaned the outside of it with a brillo pad . there is no oil what so ever leaking into the motor from the gearbox so i recon someone must have squirted some onto the pump in an effort to get it going [all its done is spray it all over the motor and the inside of the cabinet ]The inside of the cabinet has also been scoured ready for a rub down before paint and the wringer has had a coat of fresh white paint. i used up some grey paint on the bottom of the cabinet
Post# 1190050 , Reply# 7   9/15/2023 at 15:44 (231 days old) by anthony (uk)   |   | |
Post# 1190317 , Reply# 8   9/20/2023 at 13:21 (226 days old) by anthony (uk)   |   | |
done today .Motor reassembled and all new hoses fitted . the cabinet has been sanded and primed and i painted the inside with bit of white gloss I found in the garage [we must all have tins lurking with bit of unused paint in them] didn't want to use up the white spray paint .the usual jewellery has also been polished and I found that the plastic insert from an old desk is the perfect fit for the perished rubber ring that fitted the opening for the plug.
Post# 1190327 , Reply# 9   9/20/2023 at 17:04 (226 days old) by Slowspin66 (lincoln uk)   |   | |
Post# 1190417 , Reply# 10   9/21/2023 at 16:35 (225 days old) by anthony (uk)   |   | |
Post# 1190558 , Reply# 11   9/24/2023 at 13:52 (222 days old) by anthony (uk)   |   | |
take the pump off again as its not working properly .Although I have scrubbed and scrubbed the rubber tyre on the pumps pulley it still seem to have oil coming out of it [whoever tried to oil the pump must have saturated it ] causing it to slip so I decided to try fitting a bit of rubber pipe and after tightening the spring its working as it should with no leaks anywhere .I will leave it overnight with water in it just to make sure its watertight also put a washer on the pump mounting post to stop it wobbling .I have to say the machine is so quiet even when the washer is running there is just a low hum from the motor not even a gentle thud thud as it goes back and forth . I was surprised to find the older machine is 2 inches shorter than the other . I forgot to mention that the machine came with its enamel worktop
Post# 1190878 , Reply# 12   9/29/2023 at 15:25 (217 days old) by anthony (uk)   |   | |
can get a new switch for this machine i have cobbled this together so it at least looks the part .the switches are push on and push again for off so only one needed really but i am fitting two purely for cosmetic reasons. in the last photo the switches are not fitted yet i just put them in position to see if they would look and work properly .All seems well so i will fit them properly tomorrow
Post# 1190919 , Reply# 13   9/30/2023 at 02:21 (217 days old) by Slowspin66 (lincoln uk)   |   | |
Post# 1191389 , Reply# 14   10/6/2023 at 15:47 (210 days old) by anthony (uk)   |   | |
pump problems with this machine so I think I will just bite the bullet and fit an electric one .The two buttons on the front of the machine are now two independent switches the red one switching power to the motor so I will use the black one for the pump .changing the subject a little my workshop and machine storage is a big shed at the bottom of a very large garden with just a sink and cold water to play with so when I want to use the empress I have to push it up the garden path to the house or carry buckets of hot water to the shed .last week I saw this little gadget being used on YouTube .At first glance I was quite shocked to see this device in a bucket of water while connected to the mains once I got over that I decided to buy one .today I tried it out on the Empress and I have to say it did very well heating cold water to just below boiling in 50 mins I imagine if left for an hour it would bring the water to the boil . Its made in China so don't know how long it will last[only cost £9.99] and I wouldn't touch the machine while its switched on but it certainly works well enough
Post# 1191978 , Reply# 15   10/15/2023 at 12:04 (201 days old) by anthony (uk)   |   | |
new electric pump fitted .Its not quite as powerful as the old one but it works perfectly and those new car cooling system hoses are so strong there's no need to mount the pump on anything .Its held in position by the hoses and the added bonus it the extra filter built into the pump .The new switch arrangement is covered in shrink tubing and then a stout plastic bag same with the connections to the pump. I will keep the old pump with the machine just in case it can be repaired at a later date so all is good .The machine could do with a new bottom roller but I probably have more chance of winning the lottery than finding one
Post# 1192028 , Reply# 16   10/16/2023 at 07:34 (200 days old) by ricky5050 (Durham Britain)   |   | |
Post# 1192043 , Reply# 17   10/16/2023 at 16:35 (200 days old) by anthony (uk)   |   | |
