Thread Number: 94328
Upgrading Maytag A512 to LA-712: Wiring Harness Problems |
Post# 1190216 , Reply# 1   9/18/2023 at 12:10 (228 days old) by Kroscavage (Ketchikan)   |   | |
In the images of the rear side of the control panel, you can see that I currently have the 2-07366 and 2-07367 switches installed. However, I plan to replace them with the correct2-06218 and 2-06219 switches. |
Post# 1190217 , Reply# 2   9/18/2023 at 12:43 (228 days old) by Kroscavage (Ketchikan)   |   | |
Here are more pictures. They show the entire back side of the new LA-712 control panel, the older A512 control panel, and the back side of the LA-712 timer. |
Post# 1190243 , Reply# 3   9/18/2023 at 22:31 (228 days old) by maranoman (Des Moines, Iowa)   |   | |
Attached are the wiring and ladder diagrams for the A712 from the Maytag service manual.
Post# 1190245 , Reply# 4   9/18/2023 at 22:38 (228 days old) by maranoman (Des Moines, Iowa)   |   | |
Post# 1190246 , Reply# 5   9/18/2023 at 22:51 (228 days old) by maranoman (Des Moines, Iowa)   |   | |
(1) Which color wires are meant for the lid lock? On one end of my lid switch there is a Yellow wire marked "SW" that originates from the timer terminal marked "SW". On the other end of the lid switch is a Yellow/Black wire that comes from the water level switch. (2) Where should the orange wire from the motor be connected? It goes to terminal 31 on the the motor control switch on the console. (3) How should I connect the orange and black wires from the water valve? The orange/black wire from the hot water valve solenoid goes to the terminal marked 6 on the water temperature selection switch on the console. (4) What are the differences between the LA-716 and the A-716? The LA712 is the almond colored cabinet. The A712 indicates the white color cabinet. They use the same wiring schematic. |
Post# 1190271 , Reply# 6   9/19/2023 at 11:57 (227 days old) by Kroscavage (Ketchikan)   |   | |
Maranoman, your assistance is greatly appreciated. You went the extra mile by removing the timer to capture the back of the timer photos. The ladder diagram proves especially valuable in understanding the electricity flow. Thank You
