Thread Number: 94372
Maytag Neptune Washer MAH4000AWW |
Post# 1190512 , Reply# 1   9/23/2023 at 16:29 (223 days old) by cfz2882 (Belle Fourche,SD)   |   | |
not much to go wrong with the motor,but the motor control could need repair or replacement...Neptune experts should chime in soon :) I have a 3000 from 1998 :) |
Post# 1190526 , Reply# 2   9/23/2023 at 20:27 (223 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
There are many things that could be wrong, one of the most likely, however, is the motor board, it could also be the main control board problems with the door, lock assembly, etc.
Maytag revise the motor and motor board so you have to match the two together it’s more likely the motor Ford is bad than the motor but you might have to change both depending on what you can find. There’s a check out chart inside the control panel that tells you how to decide what is wrong you need to go through the checkout before replacing parts. John |
