Thread Number: 94431
1968 kenmore rebuild |
Post# 1190984   9/30/2023 at 20:40 (216 days old) by mopar65 (Almont MI)   |   | |
Over the last year the 1968 kenmore started to leak and get a little loud on spin. Decided today that it needed to come apart and get rebuilt. Hopefully I ordered the right replacement parts for it. The spin tube was an absolute nightmare to get out! Destroying it in the process was unavoidable. As you will see in the pictures the center post rust has progressively gotten worse over the past 5 years, I’m thinking about ether driving a pice of exhaust pipe over it or cutting the welds on the base and replacing it altogether with a pice of exhaust pipe. It’s actually the same exact size as a small exhaust pipe that is easily obtained locally and in SS. Has anyone ever tried that before?
Post# 1190985 , Reply# 1   9/30/2023 at 20:54 (216 days old) by mopar65 (Almont MI)   |   | |
Post# 1190987 , Reply# 2   9/30/2023 at 21:58 (216 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1191017 , Reply# 4   10/1/2023 at 06:05 (216 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi Anthony, glad to see you attacking this project finally.
There’s a trick to getting those stubborn spin tubes out, I dismantle the washing machine from the top and pry the spin seal out and then you put the machine in spin and you use an old screwdriver or something to grind all the rust off the spin tube at the top with the machine running in spin so that the spin tube will slip out through the bearings. To repair the center post if it’s not completely rusted away, Smitty found some thin stainless steel tubing that slips right over the center post and he would tack weld it at the top and at the bottom, it was thin enough that you could still force the outer tub center seal down over it and get a good seal, we restored about six belt drives this way, need to get some more tubing. Check in with me. If you need any parts, you know I have anything you need for that machine probably. John |
Post# 1191335 , Reply# 5   10/6/2023 at 01:10 (211 days old) by mopar65 (Almont MI)   |   | |
John that would have definitely made it easier that’s for sure! The seal was leaking and the shaft was rusty in the bearing, I believe that is why it was so hard to get out.
Ended up sleeving the center post. Getting it and the base ready for paint. Just finished up with a level one cleaning of the transmission. Don't know if you remember John when we were talking about a way to check the oil level, after opening it up it was definitely low on oil as there was almost nothing in it, what was in it was basically wax (thicker than motor honey) almost as thick as bearing grease. A light amount of fine metal particle was there (what would be normally found in a car automatic transmission that was still working properly) don’t think that will be an issue. Will give you a call in a day or so and see what you think.
Post# 1191380 , Reply# 6   10/6/2023 at 15:13 (210 days old) by bendixmark (Winchester Mass)   |   | |
I use clear silicone to seal those tubs and it lasts forever. I have rebuilt dozens of machines like yours.I have a 68 800 pair. |
Post# 1191814 , Reply# 7   10/12/2023 at 18:01 (204 days old) by mopar65 (Almont MI)   |   | |
Post# 1191815 , Reply# 8   10/12/2023 at 18:04 (204 days old) by mopar65 (Almont MI)   |   | |
Post# 1192235 , Reply# 9   10/19/2023 at 22:25 (197 days old) by mopar65 (Almont MI)   |   | |
It’s all back together. Going to give it a test run in the morning.
Post# 1192241 , Reply# 10   10/20/2023 at 00:44 (197 days old) by 114jwh (Vancouver)   |   | |
Congratulations Anthony. It looks like it just came off the showroom floor - I bet your rebuild was a lot of work but your results were well worth it! Hope the testing goes without a hitch. Congrats once again! |
Post# 1192279 , Reply# 11   10/20/2023 at 14:20 (196 days old) by Maytag85 (Sean A806)   |   | |
Post# 1192281 , Reply# 12   10/20/2023 at 14:38 (196 days old) by mopar65 (Almont MI)   |   | |
Well it’s working better than it ever has sense it’s been in my care. Only two things so far. I was so excited that I hooked the water supply hoses up backwards lol and apparently I didn’t do a good job adjusting the clutch, it’s dragging a touch.
No leaks anywhere and the transmission is quiet with fast smooth shifts. |
