Thread Number: 94495
/ Tag: Modern Dryers
Samsung Dryer Spins Too Fast |
Post# 1191655   10/9/2023 at 22:45 (201 days old) by pumper (SE Wisconsin)   |   | |
Bought this three year old gas steam dryer on FB for $50, said it didn't heat. Wanted to tinker so I bought it and tested/replaced the gas valve coils and belt. Heats like a champ now but drum turns too fast. Clothes come out horribly wrinkled. So I fired up the parts cannon:
1. OEM main control board. Didn't fix it. 2. OEM motor (came with blower, mounting bracket/clamps, idler pulley & spring). Didn't fix it. 3. OEM wiring harness. Didn't fix it. These OEM parts were sold as "open box" but what are the chances I would get a part with the same problem? Lol The video doesn't really do it justice. Wet clothes barely drop at all, mostly from the two to four o'clock position. I think clothes should drop no later than the 12 o'clock position for proper drying. There's not much about this on the web, mostly dealing with a cracked motor pulley which would allow the belt to ride on the motor shaft instead. This part looked good on mine but I replaced it anyway. It didn't help. I have three other dryers and none have this issue. A few years back I bought a used LG dryer that did the same thing, and I ended up just getting rid of it a few months later. I put the old belt back on and retested, with the same results. About the only things left to replace are the boards for the dial and display, but I don't know why those would cause this. Any ideas? Model DVG45R6100P/A3 CLICK HERE TO GO TO pumper's LINK |
Post# 1191656 , Reply# 1   10/9/2023 at 23:08 (201 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1191700 , Reply# 3   10/10/2023 at 13:00 (200 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1191701 , Reply# 4   10/10/2023 at 13:01 (200 days old) by Maytag85 (Sean A806)   |   | |
Post# 1191728 , Reply# 5   10/10/2023 at 22:00 (200 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 1191903 , Reply# 6   10/13/2023 at 23:49 (197 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
I believe they're Korean dryer characteristics. |
Post# 1191947 , Reply# 7   10/14/2023 at 16:40 (196 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1192017 , Reply# 8   10/16/2023 at 00:34 (194 days old) by lotsosudz (Sacramento, CA)   |   | |
Post# 1192040 , Reply# 9   10/16/2023 at 12:00 (194 days old) by RyneR1988 (Indianapolis)   |   | |
Sean, I agree with this completely. Even when it comes time for me to get a new washer, I'll likely keep my old Whirlpool 29-inch dryer because there is nothing whatsoever wrong with it. And when it dies, I'll get another WP 29-incher if they are still being made even if I have an FL washer from another brand. I don't care a bit about matching machines because my laundry is in a closet, the doors are always closed, and no one sees them anyway unless they are being used.
Only thing is 29-inch WP dryers max out at 7-cu ft so would it be able to keep up with the larger volume of laundry produced by high-capacity modern washers? I'm thinking probably so, because modern dryers are mostly around 7.4-cu ft so not much of a difference there really. Ryne |
Post# 1192072 , Reply# 10   10/17/2023 at 10:56 (193 days old) by rinso (Meridian Idaho)   |   | |
Yeah, My LG Dryer does the same thing, unless it is fully loaded. It also requires quite a full load for the moisture sensor to work properly. I'm sure it is an engineering and design issue and not really repairable. |
Post# 1192075 , Reply# 11   10/17/2023 at 12:22 (193 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1192078 , Reply# 12   10/17/2023 at 13:57 (193 days old) by appnut (TX)   |   | |
