Thread Number: 94501
Dish washer Dry/heat problem looking for advice. |
Post# 1191724 , Reply# 1   10/10/2023 at 21:29 (200 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 1191741 , Reply# 2   10/11/2023 at 06:18 (199 days old) by Jmirawm (Barling Arkansas)   |   | |
I’m not sure how to check for motherboard failure. The dishwasher will run all cycles and go through all it’s paces. Just not getting water hot or any drying heat. |
Post# 1191750 , Reply# 3   10/11/2023 at 11:04 (199 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1191751 , Reply# 4   10/11/2023 at 11:38 (199 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
if you can post a picture of the dishwasher itself or post a video of the dishwasher might help, and next time you run a cycle i would try to do the following if the dishwasher has a high temp wash option and sanitize rinse option turn those options on to see if it heats the water and check if the heat dry option is on and have a plumber check the water tempature of the water heater as well
Post# 1191754 , Reply# 5   10/11/2023 at 12:08 (199 days old) by Egress (Oregon)   |   | |
Sounds to me just based upon the description that you may have a failed heating element, but I can't be sure without more information. |
Post# 1191756 , Reply# 6   10/11/2023 at 12:28 (199 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1191758 , Reply# 7   10/11/2023 at 12:54 (199 days old) by appnut (TX)   |   | |
Post# 1191770 , Reply# 8   10/11/2023 at 20:14 (199 days old) by Jmirawm (Barling Arkansas)   |   | |
They are running it with the “high temp” and “dryheat” option selected. That is the model number on inside of door. I’ll include pictures of badges and model number.
Post# 1191771 , Reply# 9   10/11/2023 at 20:21 (199 days old) by Jmirawm (Barling Arkansas)   |   | |
Is that the model number on the “America” sticker in the middle above? W10537650 ?? Seems like an odd place. That’s a sticker on the front panel. |
Post# 1191778 , Reply# 10   10/11/2023 at 23:26 (198 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1191782 , Reply# 11   10/12/2023 at 07:38 (198 days old) by Jmirawm (Barling Arkansas)   |   | |
I’m not sure where else to find the model #. The light grey sticker is from the inside door edge. The other sticker is on the outside door panel. Here’s a control panel pic.
Post# 1191784 , Reply# 12   10/12/2023 at 09:04 (198 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Left side of tank
Post# 1191787 , Reply# 13   10/12/2023 at 09:13 (198 days old) by DADoES (TX, U.S. of A.)   |   | |
The model/serial tag should be on the edge of the tub frame, could be left or right side. This is a Frigidaire at a friend’s house where I’m visiting.
Post# 1191798 , Reply# 14   10/12/2023 at 11:30 (198 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1191811 , Reply# 16   10/12/2023 at 15:46 (198 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Base on what you are saying with the model number and serial number i have found this on google but i am not an expert but here the link if you went to read up on this
howtofixit.net/whirlpool-dishwas... |
