Thread Number: 94587
Whirlpool LSR8200EQ0 Intermittent Slow Spin/Burning Smell |
Post# 1192469 , Reply# 1   10/24/2023 at 13:00 (186 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1192470 , Reply# 2   10/24/2023 at 13:02 (186 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1192472 , Reply# 4   10/24/2023 at 14:05 (186 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1192499 , Reply# 6   10/24/2023 at 22:04 (186 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1192500 , Reply# 7   10/24/2023 at 22:11 (186 days old) by coldspot66 (Plymouth, Mass)   |   | |
Check to see if there is something caught between the inner and outer tub....maybe a sock or small article of clothing. |
Post# 1192563 , Reply# 9   10/26/2023 at 08:00 (184 days old) by thatwasherguy (Kentucky)   |   | |
I once saw a direct drive with a bad tub seal that was leaking water onto the clutch, causing it to have issues spinning, but it doesn't sound like that is happening to yours. Is it possible that the brake is getting stuck every now and then? As for getting the tub out, I would recommend soaking the tub nut in penetrating oil for an extended amount of time before removing it, as you may find that it is seized in place.
Hope this helps, Thatwasherguy. |
